Results 1 to 6 of 6
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Would these wheels and tires fit?
    Will these fit on a 2001.5 S4?
    Front Wheels: Nad-1 Hyper-Black 19x8.5 35mm Offset
    Tires: General Exclaim 235/35/19 with Discount Tire Certificate which covers life time replacement and balancing.
    Rear Wheels: Nad-1 Hyper-Black 19x10 35mm Offset
    Tires: General Exclaim 265/30/19 with Discount Tire Certificate which covers life time replacement and balancing.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Would these wheels and tires fit?
    U will have issues with rear rub unless you put a pretty big spacer on it i think
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Oct 30 2007
    Pasadena, MD
    How bad. What size spacer would i need and how bad would it look with the spacer? Thanks everyone.
    Veteran Member Four Rings McKennaS4's Avatar
    Sep 25 2006
    2500 dodge ram diesel
    Boston, MA
    skip it... 10" wheels will look like ass on the rear... only way to make em work is with about an inch of poke! the fronts should be fine though.
    01 Casa sedan 6MT, sport, cold
    Active Member Four Rings
    Dec 11 2006
    Boston
    spacers on teh back would cause even more rub...
    Stage 3+ RS6's
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    10s wont work sorry. if they are two peice or 3 peice. maybe you can get a different sized barrel and lip to make it a 9 inch.
