Results 1 to 14 of 14
    Senior Member Two Rings Asix's Avatar
    Jan 25 2008
    Audi S5
    Bellevue, WA
    Fender rolling due to rubbing issues
    Hey guys,
    I just had my 19" RS4 replicas put on my A6. I got falken 245/35/19 and my car is also lowered on eibach pro-kits. I'm experiencing rubbing issues whenever I drive on the freeway or hit a dip in the road. Has anybody had issues with rubbing issues and if so, did you get your fenders rolled? Any help is greatly appreciated!
    Veteran Member Four Rings Gigi's Avatar
    Jan 23 2006
    2004 Audi A6 2.7T, 1999 Jeep W
    Charlotte, NC
    Re: Fender rolling due to rubbing issues
    Your tires are bigger than the recommended size which is 235/35/19, and some tires are bigger/squarer than others within the same size. So by going to to 245, you increase your chnace to experience rubbing.
    In addition, I assume from your psot and sig that you have springs on.y, which is not the best route to go. It is always betetr to do shocks too because 1- you'll wear your OEM shocks faster and end up relpacnig them, paying for labor a secnod time, and 2- lower more aggressive springs on stock shocks rsult in bouncing, which here is impactnig you by increasing rubbing as the car buonces over dips on the road.
    However, a little rubbing is not necessarily super bad.. where does it rob? not the inner tire wall right? is it just the outter corner of the tire? and is it rubbing against the liner or fender edge or the little screw that holds the liner...
    I had some rubbing wiht my 19s before and melted a portion of my liner, really no consequence.. except for a little extra tire wear
    Have a great day, Brice
    99 Jeep TJ, 4" lift, Mikey Thompson rims & tires
    http://i157.photobucket.com/albums/t...i/photo-22.jpg
    http://i157.photobucket.com/albums/t...20TJ/Jeep2.jpg
    SOLD: 04 Blue [B]A6 2.7TStage 2 +: Many mods
    Jan 23 2006
    Charlotte, NC
    oh and yeah you can try rolling the fender but figure out where it rubs first to make sure it'll help
    Feb 07 2008
    Newport Beach
    Wood baseball bat, a floor jack and patience, Your hands and arms will be sore but it works great. It is a good Saturday beer drinking project because the thought of a baseball bat near fenders and paint, just dosent sound right.
    Jun 19 2007
    03 Audi A6, 06 Denali
    Bakersfield, CA
    I used an aluminum bat with I rolled the fenders on my bagged truck once. Worked like a champ.
    I have Eibach's and run a 245, and I only rub on the rivot on the front fenders on big dips. Other than that, I don't ever rub at all.
    "hit the clutch, the gear, the gas, and I'm gone"-- 50 Cent
    Nov 18 2005
    Pair of (. )( .)
    yeah, front needs to be rolled, with rolled front i ran 265 track tire...(it was 255 Hoosier equivalent to 265 road tire)
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad(old) 10 Q5 10 S4 13 S6
    T.O.
    and get your wifie to hold the hairdryer
    Established Member Two Rings THM's Avatar
    Jun 06 2007
    Audi A6 4.2
    Chicago
    if you are going to roll fenders do it right, with heatgun and spec tool to roll them
    2000 a6 4.2
    Feb 01 2008
    Missouri
    Does anyone have before/after pics. I want to get an idea of what type of diffrence this makes.
    Nov 26 2007
    San Diego, CA
    yes please. i could go for some pics. asix if you do this do another DIY
    Jan 25 2008
    Audi S5
    Bellevue, WA
    went back and got 235/35/19's. Got a $160 refund for getting a smaller tire and they don't rub at all!
    Feb 21 2004
    T.O.
    it doesn't really look any different just that metal lip is folded up
    Jan 23 2006
    Charlotte, NC
    thought so, I had the same problem with the goodyear 245's and had to get them exchanged.
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Quote Originally Posted by Asix View Post
    good idea!
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
