Results 1 to 13 of 13
Thread: Transmission
    Apr 02 2008
    California
    Transmission
    My car is downshifting hard and it feels like it jerks when im coming to a stop on my 2.0 quattro is this normal? my dealer said all quattros do that is this true. By the way my car is automatic
    Veteran Member Four Rings quattrosaint's Avatar
    Sep 24 2007
    Dallas
    Re: Transmission
    Quote Originally Posted by pressurized2.0 View Post
    not normal. It should automatically stay in second till the car comes to a stop or if you use tip mode you can make it go into first. The car should not jerk
    2007 A4 Quattro 2.0T Tip
    Go Fast:Custom GIAC Tune & APR HPFP & AWE FMIC & AWE Exhaust & Labree DP & K&N Filter & Forge DV & Eurojet PCV
    Stop: ECS Stg 4 Porsche BBK
    Twisties: H&R Springs & RS4 Sway & Ti Rims
    Stunt: S4 Grill & S4 Rear & Cupra R Spoiler & TTS Wheel & 8MM Spacers & CF Trunk
    Now................Mostly parted out. Thanks everyone who participated
    Oct 01 2007
    Location, Location, Location
    Re: Transmission
    I am also having the same problem. I took it into the dealer and test drove it with one of their techinicians who claims that it is part of the way that the engine works. It happens to me whether or not i am in Tip or Automatic.
    Mar 02 2007
    Brisbane, Australia
    Re: Transmission
    Tiptronic ? Sounds like this same issue I posted here:
    http://www.audizine.com/forum/showthread.php?t=176333
    My problem dissappeared after a few weeks. Hasn't done it since for months...
    I'm led to believe that the ECU learns driving style and adapts - I dunno - weird how it suddenly appeared and went away again.
    Recently had a dealer service, software update performed but none of those dumbskulls could tell me what the software update addressed....
    Registered Member Two Rings
    Mar 25 2008
    Audi A4 2.0T MT
    Knowlton,Quebec, Canada
    Re: Transmission
    Did you try a manuel 6 speed transmission on a A4 2.0T? I'm thinking of buying a A4 2.0T cabriolet but it only comme whit the tip trans (I want the quattro). My last 15 cars was all manual. Is it really fun???
    KKKY
    A4 B7 2.0T, Neuspeed RS10 19inch, race spring, Bilstein, Sway bar , exhaust Neuspeed, BBK ECS 14", Neuspeed ECU
    Previous Rides
    2003 BMW M3 cab
    2000 Volvo S70 T5 full IPD
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Re: Transmission
    The problem has to do with transmission software and the Clutch converter lock up. The way newer transmissions are designed is that the torque converter clutch stays locked up at low speeds and only unlocks to switch gears or during heavy throttle. The reason for this is fuel economy because when the converter is locked there is no slippage aka the same way a manual transmission works. What you are feeling is when the car downshifts and the torque converter clutch engages and disengages. The problem is with this transmission programming, the rev matching is not as good as it could be so you are going to feel it more.
    My 2006 BMW x5 with the similar ZF transmission has the same issue. It has gone away with more miles because the clutch becomes softer due to wear.
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Three Rings CX-7&A4's Avatar
    Dec 09 2007
    CX-7 AWD/A4
    Foreclosure Captial of the US
    Re: Transmission
    CVT or Tip?
    07 Mazda CX-7 AWD
    06 Audi A4 Fail2Trak CVT - TRW Front/Mintex Redbox Rear
    Senior Member Two Rings acbrooks2's Avatar
    Oct 10 2007
    2006 2.0T Quattro
    California
    Re: Transmission
    I experienced this on my B7 wagon and thought it was a bit odd. One of the reasons i went to a 6-speed manual - much better. Having manual transmission transforms the car IMO. I have heard the new paddle shift auto transmission is much better than the Tip tho.
    2006 A4 2.0T Quattro 6-Speed, H&R Street Performance Coilovers, ECS Stealth Black Grille & Panel, De-badged, RS4 mirrors, Trunk Spoiler, Red LED Interior, Lumar Tint - 50% front 35% back, H&R Trak Spacers - 10/12mm f/r, Neuspeed Short Shifter, Neuspeed Snub Mount, REVO Stage 1, Neuspeed 70mm Cat-Back Exhaust, K&N Air Filter, Hoen Xenonmatch Fogs, PIAA City and DRLs, VAG-COM Seat Belt Chime, RotW lights & Door/Window Lock, color-coded sidemarkers, smoke side blinkers, Denison iPod to RNSe
    Apr 02 2008
    California
    Re: Transmission
    Guess What guys just found out its not normal my tranny is gone! It does not go into reverse and has no acceleration
    Dec 09 2007
    CX-7 AWD/A4
    Re: Transmission
    Sounds like it's been fried, have you checked the fluids and stuff?
    07 Mazda CX-7 AWD
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Re: Transmission
    Still doesnt sound like the problem you are talking about. sounds more like a coincidence to me.
    All go no show
    Dec 09 2007
    CX-7 AWD/A4
    Re: Transmission
    We had an old Bravada that had a leaking seal and it would not move the car, turns out the transmission seized.
    07 Mazda CX-7 AWD
    Apr 02 2008
    California
    Re: Transmission
    on saturday i took my car to penske and they let me test drive a quattro to see if it was normal and the service consultant said its not because the other quattro doesnt do and later that day when i drove home my tranny started tugging hadr on fourth gear and then the PRNDS suddenly was highlighted in Red so i pulled over and when i tried taking off it didnt move. Then i turned it off and then back on again and then my acceleration was slow like really slow. Then i tried going in reverse and it didnt move at all it felt like if i had it in neutral
