Results 1 to 6 of 6
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    vagcom bonuses???
    with the vagcom mods, what does bonus 1 and bonus 2 actually do?
    **Bonus 1** Enable Dashboard Headlight Indicator
    Module 17 (Instruments), recode to ??###, where ?? = [existing 2 digit value - 2]
    is there an icon that lights up when i turn on my headlights?
    **Bonus 2** Trip Computer Fuel Consumption Correction Factor
    Module 17 (Instruments), Adaptation channel 03
    - Affects: Instantaneous Fuel Consumption, Average Fuel Consumption, Range, & Distance to Empty
    - Default: 100%
    - Range of values: 85 – 115%
    i'm guessing this mod will update the factor instantaneously instead of 33 yards of travel?
    and with bonus 3
    **Bonus 3** Disable Auto-Lock
    Module 46 (Central Convienence), recode to [existing value - 32]
    i don't have auto-lock on mine, so how would i enable it?
    thanks...
    DUH! an Audi
    los angeles, CA
    Re: vagcom bonuses???
    3, when you drive it will no longer lock the car after you start to drive
    other 2 no clue
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    oh ok, i thought it's when you leave the car, it should autolock.
    DUH! an Audi
    los angeles, CA
    I think to enable it you add 32, to be honest when I did the window trick it removed the auto lock =\
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    1, Yes there is a light that will illuminate when your lights are on. 2, That adjusts your Average MPG calculator that appears in the display in the gauge cluster. By adjusting the percentage you can get it closer to accurate by changing it and tracking your MPG manually and comparing that to the cars estimate. Then you just adjust it based on what you have calculated as the difference. 3, what Quattro said is correct.
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    thanks guys, appreciate it.
