Results 1 to 7 of 7
    Senior Member Two Rings Mrsfourrings's Avatar
    Jul 31 2007
    2001.5 E85 STG 3 S4 Avant 1993 Corrado VR6
    Help what to do?
    I am at a crossroads-I have an auto b5 A4 1.8t I don't know what to do for
    more power. Car already has KO4 set-up. Should I ditch for a bigger turbo,
    I also have a complete b5 s4 swap, or possibly do the 034 vr6 swap?
    Help!!! P.S. I already have a stg 3+ b5 s4
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: Help what to do?
    Quote Originally Posted by Mrsfourrings View Post
    Buy an Evo.
    lol
    Id do a gt series turbo
    Sep 24 2007
    Woodbridge, Ontario
    and stroke out the 1.8 to 2.0
    Veteran Member Three Rings ChescoS6's Avatar
    Jan 13 2007
    2012 Golf TDI 2003 Ducati ST4s ABS 2007 Ducati Monster S2R
    PA
    I find this post confusing.
    You already have a Stg 3+ B5 S4 AND you have an S4 swap for the A4? Why do you need 2 really fast cars to begin with? Why not keep the A4 for a DD?
    In one of your previous posts you state you have a lvl 10 VB. What did it run you and what's your opinion on it? Worth it?
    Jul 31 2007
    The level ten valve body and torque conertor def. made a diffence. Lots more
    positive feel when gears change!
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    so ur saying that u've got a b5 1.8t...u swapped it w/ an s4 motor, and are at 3+ on the s4 motor... if i remember right, those are 2.7tt. what power numbers you at? is it possible to bore/stroke to 3.0 or 3.2? cam? maybe start losin weight on the car. carbon fiber hood/trunk, i hear the windows can be swapped for lexon or whatever the glass is called that racecars use. they would still go up and down, just weigh less... theres' always nitrous, or water/meth injection too! a nice goal would be to build a bulletproof engine!! like take off the wastegate and just let the turbo spool. use a standalone fmu and just figure out what the max boost the turbos can handle and calibrate for the fuel. these are just some ideas!! or worst case scenerio, consider the a4 done, and get an old gsx.... those are always fun to toy with... good luck, keep us up to date with what ya plan on doin!!
    Jan 13 2007
    PA
    How much was it for both and where did you have them installed or did you DIY?
