Results 1 to 6 of 6
Thread: vag com boost
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    vag com boost
    i am meeting up w/ a buddy to diagnose my boost readings. is there anything other than requested vs. actual boost that i should log to determine if i have a boost leak or if my dv or n75 is failing?
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Sep 20 2004
    Paradise Valley, AZ
    Re: vag com boost
    bump
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: vag com boost
    See the first 2 links on this page:
    http://www.mjbmotorsport.com/tech.html
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Veteran Member Three Rings MarkChai's Avatar
    Feb 01 2007
    1998 Titus Quasi-Moto
    SF, CA
    Re: vag com boost
    I remember reading somewhere that you can do an output test for the N75, but that might have been for diesels only.
    Formerly:
    B7 A4 Saloon CVT :P
    C4 A6 Avant Quattro
    B6 A4 Avant USP 6QM
    B5 A4 Saloon Q-Tip
    Jul 21 2004
    South Florida
    Re: vag com boost
    you can check n75 duty cycle and wastegate duty cycle I believe. I cant recall the channels but do a search on here or audiworld and youll get the channels. I just scroll a bit til I find them.
    2018 Audi S5
    Gone-
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Re: vag com boost
    we were just jacking around with mine on VAG, the channels start at 111 i believe. i forgot what buttons we were clicking, but it show all the things it monitors and what channel number it was. but it does show boost, and the N75 valve info, boost is in nBar or something like that.
