Results 1 to 8 of 8
    Registered Member Three Rings projectdarka4's Avatar
    Jun 08 2007
    2000 a6 2.7t tip
    illinois
    wheels wouldnt fit?
    So i bought 19x8.5 and 19x10 from a guy on here with a 2004 a6 2.7t s-line. the wheels were an offset of 35.. i have a 2000 a6 2.7t and they wouldnt fit on the front... the brakes were too big.. what would be the issue??? thankfully he returned the wheels, but now im back in the market, but dont want to have the same issue again...
    Nov 18 2005
    Pair of (. )( .)
    Re: wheels wouldnt fit?
    should have run a spacer, never hurt anybody
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Veteran Member Three Rings onewicked's Avatar
    Sep 25 2007
    2001 A6 2.7t
    Dirty Jersey
    yup...had the same issue...i bought 19 with a 35mm offset.. but front brakes were too big so i just added a spacer
    2001 Audi A6 2.7t
    THE C5 UNION
    Past cars:
    1998 BMW 528i Sport
    1995 Eagle talon TSI w/ 6bolt swap(for sale)
    1996 VW jetta VR6
    1998 VW jetta 2.0 Turbo
    AMS AUTOWERKS #1
    Mar 11 2007
    Colorado Springs
    The 2000 & 2001 C5 2.7t have HP2 calipers, which require wheels with a unique curvature of the spokes, while the 2002 - 2004 have a smaller caliper that will fit most wheels that are 5x112 with an ET35.
    Jun 08 2007
    2000 a6 2.7t tip
    illinois
    so if i need a unique curvature... how wil i know if the wheels will fit or not? or can i get the calipers from a 2002-2004 and swap it??
    Veteran Member Four Rings Gigi's Avatar
    Jan 23 2006
    2004 Audi A6 2.7T, 1999 Jeep W
    Charlotte, NC
    use wheels that another member has and knows works for sure, use a seller with a site where you can shop by model/year.... call a shop....
    www.tirerack.com
    www.gmpperformance.com
    often times a spacer helps but might put the wheels out too much for you or.....
    better to go with a safe choice liek a wheel someone else uses or has used on the same car OR talk to a pro
    Have a great day, Brice
    99 Jeep TJ, 4" lift, Mikey Thompson rims & tires
    http://i157.photobucket.com/albums/t...i/photo-22.jpg
    http://i157.photobucket.com/albums/t...20TJ/Jeep2.jpg
    SOLD: 04 Blue [B]A6 2.7TStage 2 +: Many mods
    Jun 08 2007
    2000 a6 2.7t tip
    illinois
    thats what i did.. i figured since they were on a 2004 a6 2.7t i would have no issue... well look again
    Jan 23 2006
    Charlotte, NC
    different years though! Brakes make a big difference for wheel fitment
