Results 1 to 17 of 17
Thread: horsepower?
    Registered Member Two Rings idLewiLd's Avatar
    Jan 15 2008
    Brooklyn N.Y
    horsepower?
    how much power does a stock 1.8t put out
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: horsepower?
    Quote Originally Posted by idLewiLd View Post
    170
    -Sami-
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Re: horsepower?
    ^^ lol. At the crank!
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    Re: horsepower?
    105.2 AWHP Stock ..thats what I dynoed stock anyways
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Re: horsepower?
    Mine came with 1206 HP stock.
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    Re: horsepower?
    170 at the crank, you can find that and almost anything else in the stickies at the top of the b6 page
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    Re: horsepower?
    Somewhere in the realm of "not enough" and "stupid question"
    Current - 2004 Pontiac GTO 6M *FOR SALE*
    Looking for - B6/7 S4 TIP or 6M
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: horsepower?
    Quote Originally Posted by sambrody44 View Post
    Obviously. Where do you ever see HP listed at the wheels when you look at any manufacturers web site?
    Dec 06 2007
    Re: horsepower?
    No Such Thing As A Stupid Question! Maybe Act Of Being Lazy To Search Yes, But Not Stupid!
    -Kirk
    BetaAlphaTau Member #58
    Feb 17 2005
    Sarasota, FL
    Re: horsepower?
    Very very little!
    Senior Member Two Rings sailor's Avatar
    Feb 19 2008
    TBird.TC Miata A4Avant BMW.R80
    Blackhawk, CA
    Re: horsepower?
    My stock 03 1.8t Quatro was Dyno measured at the wheels.
    HP 119.1 @ 6250 RPM and torque 123.7 @ 3750 RPM
    after stage 1 REVO we measured
    HP 132.3 @ 5500 RPM and torque 149.2 @ 3250 RPM
    after software and fine tuning (pulled back on timing a bit)
    2003 A4 B6 Avant 1.8T Quattro Sport Tiptronic REVO
    Dec 06 2007
    Re: horsepower?
    ^^ At The Wheels? Cause Thats Not Even In The Ballpark Of 170!
    -Kirk
    Feb 19 2008
    Blackhawk, CA
    Re: horsepower?
    The only way you can measure it is at the wheels.
    Feb 19 2007
    Charleston, SC
    Re: horsepower?
    Quote Originally Posted by AudiA4Turbo22 View Post
    it is rated at 170 at the crank from the factory.
    who gives a hell what it is rated at the wheels in stock form
    -Sami-
    Jun 30 2007
    Raleigh, NC
    Re: horsepower?
    i think i made 113awhp and 147awtq with a full exhaust and a DV on my car....
    not exactly huge power-adders, but mods none the less.
    and fwiw, even with a stock engine i was heat-soaking like a biotch on the dyno. (i lost over 10hp between my 1st and 2nd runs... and another 7 or so on the 3rd)
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Jan 15 2008
    Brooklyn N.Y
    Re: horsepower?
    i dont think its a stupid question if so many replied ...im lookin for the best estimated range 170 at the crank from the factory i know but much less at the dyno...dont you feel riped off ...
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: horsepower?
    One cares because you'd like to have a baseline dyno bone stock to know what your car is making on that particular dyno (to calibrate against 170chp). Then you do whatever work you do and you get a new number (preferably at similar inlet conditions). Knowing your baseline results you have a factor for your car on that dyno to get to crank power.
    Quote Originally Posted by B6Lovin View Post
    Yeah. The SMIC soaks a lot huh? Mine was soaking and the ambient temps were between 30 and 40degF. Its amazing to see how my FMIC hardly gives any rise in temp even after back-to-back pulls for an hour.
    -Doug
