I''m looking to sell my JL Audio 500/1 Amp. This is the version before the slash. Has been used sparingly. It works fine with my 12W7, but I'd like to upgrade to a 1000/1.
Willing to do a trade plus cash for the 1000/1 or sell it outright. Has some cosmetic issues (scratches and such), but works perfectly.
Looking to get $280; includes shipping and paypal fees to the lower 48 states.
GENERAL SPECIFICATIONS:
Recommended Fuse Value: 50A
Recommended Fuse Type: AGU or MaxiFuse™
INPUT SECTION:
Input Type: Differential-balanced with RCA jack inputs
Input Range: Switchable from 200mV - 2V RMS to
800mV - 8V RMS
AMPLIFIER SECTION:
Amplifier Topology: H-Bridge, Class D Mono
with impedance optimization and patented
discrete drive circuitry
Power Supply: Pulse width modulation-regulated
switching power supply
Rated Power: 500W RMS x 1 @ 1.5 - 4Ω (11 - 14.5V)
THD at Rated Power: <0.05% @ 4Ω, 50 Hz
Signal to Noise Ratio: >95 dB referred to rated power
(A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 5 - 250 Hz (+0, -3 dB)
Damping Factor: >500 @ 4Ω/50 Hz, >250 @ 2Ω/50 Hz
CROSSOVER SECTION:
Amplifier Low-Pass Filter: State-variable, 12 dB/octave
Butterworth or 24 dB/octave Linkwitz-Riley with
continuously variable cutoff frequency selection
from 40 - 200 Hz, defeatable
PREAMP OUTPUT:
2-Channel, with fully independent, state-variable,
12 dB/octave Butterworth or 24 dB/octave Linkwitz-Riley
filter with continuously variable cutoff frequency selection
ADVANCED BASS CONTROL SECTION:
Parametric EQ: Single-band, fully parametric equalizer
with “Q” adjustment from 0.5 - 4.0, center frequency
adjustment from 20 - 80 Hz, boost adjustment from
0 to +15dB and port for optional remote bass
boost control (RBC-1), defeatable
Infrasonic Filter: Fully variable, 24 dB/octave Butterworth
high-pass filter, cutoff frequency adjustable from
15 - 60 Hz, defeatable
DIMENSIONS: (LxWxH):
13.4" x 9.25" x 2.36" (340mm x 235mm x 60mm)
