Results 1 to 4 of 4
    Veteran Member Four Rings mister_tu's Avatar
    Sep 27 2007
    Boston, MA
    Need help from local member (worcester)
    Hi all,
    I have to get my inspection sticker and my airbag lights are on ever since I installed my HID's. I am afraid that I won't pass inspection. From the opinion of many, they believe that I need to VAG it to resolve the problem.
    Was wondering if anyone in the Worcester area can help. I will provide the beers =)
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: Need help from local member (worcester)
    why would your airbag light be on because of HID's?
    If anything you should have a bulb out light, which you can you fix by placing a resistor in HID setup.
    Stage 3+ RS6's
    Senior Member Three Rings YBLEGL's Avatar
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    I can help if you want I live in bellingham 40 minute ride for you and my girls works in worcester actually
    MAINTENCE AND STAGE 3 INSTALLS DONE, PM ME, MASS/ RI LINE AREA
    2001.5 S4 SILVER 6 SPEED BUILT BLOCK AND SINGLE TURBO KIT WITH PTE 6262.
    Sep 27 2007
    Boston, MA
    Quote Originally Posted by deb38 View Post
    I have no idea why it is the Airbag and not the bulb. I am assuming that the ballast may be throwing some type of code.
    And YBLEGL, you got a PM.
    Thanks, guys!!
