Results 1 to 7 of 7
    Registered Member Two Rings
    Apr 20 2007
    Honolulu, Hawaii
    2003 CVT trans problem
    I got the fault codes from a local Audi shop and they said they can't fix it cause it is something in the transmission. But they gave me these fault codes 18149 P1741 clutch pressure adaptation limit reach; 18151-P1743 clutch clip monitoring signal too high. The local shop said theres something wrong with the trans pump. Do I have to change out the whole trans if there is something wrong with the trans pump???????
    what you guys think????? Audi says I need a new transmission, it's super frustrating that they can't find out what is wrong with the transmission. I mean they are supposed to be the experts since they sell them. Audi of Hawaii sucks!
    Registered Member Three Rings
    Jun 21 2007
    Fort Lauderdale,FL
    Re: 2003 CVT trans problem
    Quote Originally Posted by B6blkONblk View Post
    Go to a different dealership if you can, you don't need a new gearbox, either just a hydraulic pump or a forward clutch pack kit. Those things are under 1/3 the cost of a new gearbox including labor, but some dealerships do not know how to work on CVT's. If there is another Audi dealer, try going there.
    Apr 20 2007
    Honolulu, Hawaii
    Theres no other audi dealer in hawaii. Do you think I should call up one of the mainland dealerships??? It's hard to find mechanics that do Audi down here, since the trans and engine problems are all computerized and stuff.
    Jun 21 2007
    Fort Lauderdale,FL
    Yes, definitely contact a dealership on the mainland , it would probably be cheaper for you to ship your transmission to them to be repaired than to replace the whole gearbox locally
    Established Member Two Rings Mac's Avatar
    Jul 11 2007
    Atlanta
    Did anything happen with this? I just got the same error after it was jerking after a stoplight.
    Senior Member Three Rings A4B603's Avatar
    Jan 30 2007
    Corona, NYC
    i have a cvt trans also i want to know what can cause this, i play with my cvt all the time (go 1st stop accel go to 2nd and soo on... is this good or bad?)
    2003 A4(B6) 1.8T Sports Package
    FWD CVT
    MagnaFlow Exaust / Awe Boost Gage / Debadged / RNS-E / HKS SSQ BOV / 032 motor mounts / Carbonio V2Intake / Caractere Grille / Vagged / RS4 side Engine Cover / 1200 watt Kicker Solo Barrick 08 & Cap / Skidplate /StopTech 332 BBK / Sportec Rear / Apr Stage 1+ (apr inj.)/ VMR Sport Test Pipe / VMR 19" Rs4 Reps(gunmetal) / Falcon 452 235-35-19
    Jan 30 2007
    Corona, NYC
    FWD CVT
