Results 1 to 15 of 15
    Registered Member Two Rings
    Aug 13 2007
    Audi A4 99 Quattro
    Control arms anyone a expert?
    Ok heres my problem.
    When I go over bumps or a bumpy road I here a bunch of squeeks.. Sometimes when I'm at slow speeds I can here the suspension or whatever.
    Once I press on the right side of my car I here the same noise. When I even turn my steering wheel it makes a squeeking grinding sound. Is it my control arms? If so anyone an expert of fixing it for cheap or any shops around North Seattle that can do it for dirt? I can get the parts for cheap just not the labor.
    Thanks
    Veteran Member Four Rings Hassmeister's Avatar
    Feb 12 2004
    2015 GOLF R APR Stage 2
    Re: Control arms anyone a expert?
    Quote Originally Posted by sneekz206 View Post
    Once I press on the right side of my car I here the same noise. Is it my control arms? If so anyone an expert of fixing it for cheap? I can get the parts for cheap just not the labor.
    From North Seattle
    Thanks
    9 times out of 10 it is the control arms. You've got a '99 and if they are original they very well maybe bad.
    ECS tuning had a full control arm kit for around $600 a few years ago when I did mine.
    Expert for cheap, reasonable maybe.
    I know the guys at Matrix in Oregon are reasonable for labor rates and it's worth the drive. Ask for Jer at Matrix. The dealership will rip you off!
    Click here for AMSOIL - Superior Protection!
    Wholesale pricing and delivery to your door - ask me how!
    In Limbo Two Rings
    Feb 28 2008
    90 Corrado G60
    Portland OR
    If you would consider the noise more of a creak then it might not be the upper control arms. Those are usually more of a clunk when you hit bumps or pulling into a driveway. However, it very well could be control arms. The lowers tend to creak more than the uppers. And a lot of times sway bar links can creak really bad.
    Long story short. Could be a number of things but on that car, you can usually count on control arms.
    Senior Member Two Rings audi_a4_kid's Avatar
    Jan 14 2005
    1996 2.8 12v
    Wa
    From North Seattle
    Thanks
    Push down on the fender that you think may have bad CA. If it squeaks the arm is bad. "If there is play throw it away".
    Veteran Member Three Rings i_eat_staples's Avatar
    Aug 03 2004
    Wilsonville, OR
    i had what sounds like the exact same problem....it was the right side of my car, and it would squeek something fierce over bumps, and when the car was stopped i would press down on the right fender and could hear it
    had my control arms on the right side replaced and it didnt fix the problem...i went on a track day up at bremerton and it stopped squeeking after that
    however, the warm weather must have brought it back, because the day before yesterday i could hear it again, although not as bad as before
    '07 rs4
    '91 spec miata
    NW Quattro - NW Premier Audi Club
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Thanks
    Sounds to me like you have control arms and tie rod ends that are faulty (boots torn, joints loose). They can both creak, squeak, or clunk but the control arms usually creak/clunk and the tie rod ends usually squeak.
    You'll need to jack the car up and take the 2 upper control arms per side, grab them, see if you can move them at all. Do the same with the tie rod end on that side. Also, look for torn boots on these items.
    LMK if you have any questions.
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    May 27 2004
    Portland, OR
    Quote Originally Posted by i_eat_staples View Post
    Hey Nate,
    Just a reminder---just your right front lower leading control arm was replaced. So, the right front lower trailing control arm could be noisy now. Let us know if you'd like to bring it in for us to look at it.
    Jeremy Williams
    Aug 13 2007
    Audi A4 99 Quattro
    Thanks man ill go try that later on after work.
    May 27 2004
    Portland, OR
    Sounds good. Feel free to email me if you'd like me to send you pics of torn CA's or TRE's.
    Jeremy Williams
    Aug 03 2004
    Wilsonville, OR
    Quote Originally Posted by jeremy@matrix View Post
    Hey Nate,
    alright, i'll keep an ear on it and see if it develops. Seems to be a warm weather squeek
    '07 rs4
    '91 spec miata
    May 27 2004
    Portland, OR
    Ok, let us know.
    Jeremy Williams
    Aug 13 2007
    Audi A4 99 Quattro
    It was the upper front control arm as the other side is getting near too. Thanks man. I'm going to order the whole kit today.
    May 27 2004
    Portland, OR
    Sweet sweet!!
    Be careful with the 8pc kit including TRE's. We used one of those in the past and when the car's lower leading control arm failed down the road, a standard lower leading replacement arm wouldn't fit (it was as if the arms in the kit were unique in their own way. It was definitely strange and a pain to get the correct arm finally ordered).
    If you ever need any CA's or TRE's(we only use the heavy duty units), we always have them in stock! No sales tax either.
    Jeremy Williams
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    A lot of B5 S4's
    WA
    Hey Jeremy how much is lobor for doing all the CAs and TREs along with an alignment?
    May 27 2004
    Portland, OR
    Quote Originally Posted by michael66899 View Post
    PM sent!
    Jeremy Williams
