Results 1 to 10 of 10
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    New Clutch...Engagement Chatter Normal?
    So my new clutch is in...I got the upgraded SB HD. I believe it has the same pressure plate as an OFE SS, or something along those lines. Basically it will hold a lot more power than a normal HD.
    I've only put like 20 miles on it so far, but going into first gear is really rough...the car will chatter, or bounce a lot until it gets into gear. To put it in perspective stay in fourth gear and come to a stop, that very rough feeling before the stall is what I'm experiencing. Once in a while it'll do this while going into second, but mainly it's when going from a stop into first gear.
    Is this normal, until the clutch breaks in? If so on average how many miles until it is broken in?
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: New Clutch...Engagement Chatter Normal?
    Yes, until its broken in. About 500 city miles.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 25 2007
    MA
    great, thanks man! needed to be sure about that. if it wasn't normal i didn't want to wait 500 miles to make a complaint.
    Dec 25 2004
    Earth
    Did you get the flywheel resurfaced?
    Apr 25 2007
    MA
    yeah, i had SB resurface my flywheel. i was in a pickle though, because the work was done at my local Audi dealer and their recommendation was don't resurface. On the other hand SB doesn't provide a warranty on the clutch with a resurface job. so i went with the resurface and Audi won't give me any kind of guarantee on the work because i went against their recommendation. they do guarantee the install was done correctly though. if anything were to go wrong (knock on wood) i'm going to be hard pressed to get anything out of them....
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    ohh yea, thats right you had teh clutch ordeal!
    Definelty glad to hear that you got the FLY resurfaced!
    -Sami-
    Buncha motorcycles
    Memphis, TN
    mine does it as well, i still get it from time to time if i engage too slow, but its normal at first as it breaks in... im glad you got that thing resurfaced!
    APR Stage 2/AWE Intake
    Veteran Member Three Rings MarkChai's Avatar
    Feb 01 2007
    1998 Titus Quasi-Moto
    SF, CA
    Yeah, I've got about 350 mi. on mine and the bouncing has been gradually decreasing. At first the engagement point was really low and abrupt, but for some reason now it engages closer to stock height, but the grab is still very off/on, which I figure is just how it is. Give it a few hundred higher RPMs going into first and it'll be smoother.
    Funny thing is my stock clutch pretty much did the same thing, just not as violent, up until it died.
    Formerly:
    B7 A4 Saloon CVT :P
    C4 A6 Avant Quattro
    B6 A4 Avant USP 6QM
    B5 A4 Saloon Q-Tip
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by dirtybrd View Post
    As Chris said, it will go away. I have over 2k on my OFE SS and there are no issues.
    -Doug
    Buncha motorcycles
    Memphis, TN
    it sure scares you at first though especially if you DIY i thought WTF did i forget?
