Results 1 to 7 of 7
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    +1mm oversized valve question
    Right now I am looking at stock sized Supertech intake and exhaust valves.
    If the primary use is street and track for my car is there any benefit of getting +1mm oversized intake valves?
    I'm assuming there is related head work that needs to be done in order to make the oversized valves fit so I'm trying to figure out if it is worth the cost as I do know head work can eat up $$$ pretty fast.
    Jan 25 2006
    A4 2.0T
    MD
    Re: +1mm oversized valve question
    I am going to do OS exhaust valves, but good luck finding data to justify having that done.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    What is oversized? The valve stem or the valve seat itself?
    If it is the valve seat then that extra 1mm equates to more flow.
    If it is the valve stem then it equates to a stronger valve.
    Is it 1mm on the diameter or 1mm on the radius?
    Either way you're looking at machine work and labor. Whether its a valve seat grind or new valve guides.
    -Doug
    Jan 25 2006
    A4 2.0T
    MD
    ^ The seat.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Quote Originally Posted by winston@podi.ca View Post
    Only if you're going the run it over 7k rpm.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Mar 14 2008
    San Diego CA
    I have an AWP head with those valves in it and it does make a difference especially in the higher rpms. I also had the head p&p'd and new springs and retainers installed at the same time so I don't know what the difference would of been had I only done the valves. I know that os valve kit is $1200. Not to jack a thread or anything but my head is for sale if you are interested.
    Jun 29 2007
    Raleigh, NC
    ^ exactly what is done to it, what engine code is it off of, and how much are you asking?
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
