6th gear is made up of 2 parts and is in the rear, only 15% of the trans needs to be dissasembled. It comes off with a 2 jaw puller once the center diff is out and the rear case is off. (my Rebuild DVD would probably be offered with this as well)
Pricing on the set of 2 gears in those ratios would probably be in the $600 or $800 range. Haven't finalized pricing yet, just getting a feeler of interest to see if I should pursue this further. These are available to me now, just takes 2 to 4 weeks until I decide to go full force and stock them. Email me if you are interested now at [email protected] .
THE TECH STUFF
Our trannys have the following ratio for 6th. 0.68
I can get .56, .58 or .60 for 6th
Right now you should be at 3000 rpm at 80.
With the new ratios you would see the following RPM.
2450 rpm with .56 6th, 2550 rpm with .58 6th or 2650 rpm with .60 6th
Just to give you a reference the 5th gear ratio in our trannys is .81 yielding 3600 rpm at 80 mph. I can get other ratios for this as well but I would think this is still a usable gear since at 7000 rpm it should reach 155mph in 5th which should be more than enough for normal humans.
Thanks guys I would love to hear feedback and interest.
ACTUAL PRICING 4-07-08
I couldn't locate the .58 ratio but could locate the .60 and .56 For whatever reason one of the two gears for the .56 was pricey. Probably best to just have two options anyways since the .58 would just be in the middle of the 2.
.60 OD - 350 rpm drop at about 80 mph - JHM Price $650
.56 OD - 550 rpm drop at about 80mph - JHM Price $775 (one of the 2 gears was very pricey I will continue to shop around)
The math based on those prices
Lets do this based on an fuel economy average of 23 mpg (368 miles to a tank) I know many can do better, just being conservative.
So if the car increased 3 mpg (think more is very possible on a long trip) on the freeway you could get 416 miles to the tank. So that would be 48 miles more to the tank. Split that in half and you get 24 miles. So lets just say you get the use of 2 more gallons of gas per tank. Right now 91 octane in my area costs $3.99, but I will go with a more modest $3.50. So that is $7 savings per tank on the conservative side. So that would take 110 tank fulls on the .56 gear if it only increased by 3 mpg. And 92 tank fulls on the .60 gear ratio kit. I think if someone used 6th at lower speeds around town at about 45 mph they could save a ton. If you gas up all the way twice a week, it only takes a year to pay for itself (this is normal for commuters)
I think I need to get these gears in a car and get the real MPG gain to do the math on. But those are some numbers to chew on and get some people thinking.
