Results 1 to 32 of 32
Thread: 034 Motormounts
    Veteran Member Four Rings jursch2211's Avatar
    Feb 05 2008
    Illinois
    034 Motormounts
    So I just had my 034 mounts installed along with 034 tranny mount, all street density and WOW are there more vibrations. Anyone who has these, can you tell me if the vibrations will gradually decrease(loosen up) with wear or will they stay as is? I'm also located in Minnesota so the 38 degree weather isn't helping I know but with wear and warmer weather, will the vibrations decrease?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: 034 Motormounts
    Quote Originally Posted by jursch2211 View Post
    I am willing to bet that the shop that did the install did NOT allow the car to idle while all the mounts where still loose, so they could "seat" themselves into place.
    Another reason why one should always DIY!!!
    -Sami-
    Feb 05 2008
    Illinois
    Re: 034 Motormounts
    No they did. The guy that I had do it had his done the same way. I also told them to do it that way because of the snub mount and aligning it before they secure the mounts down. I don't know how long they ran the car or if they revved the engine. Is there anything else that I can do, or will it settle in on its own and will the vibrations decrease? I would've done it myself but I don't have anything to do that kind of work. I wish I did.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Re: 034 Motormounts
    Maybe only the motor and tranny mounts were loose and not the snub mount? If you do a search on rxrep's post of his review on the mounts, he was not experiencing any vibrations whatsoever. I'm thinking that there must have been something that wasn't loosened to allow everything to seat properly.
    USP CLUB MEMBER #34
    Feb 05 2008
    Illinois
    Re: 034 Motormounts
    I took a look at his review but I want to know what I can do, if anything, to fix this. I'm limited in what to work with. The vibrations are pretty bad, especially when excelerating. I had new exhaust put in too so I don't know if that has anything to do with it, highly doubt it though. The car doesn't really vibrate any differently, it's just inside the cabin that you can hear the vibrations.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: 034 Motormounts
    I have just the motor mounts and didn't notice any more vib. then stock.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 05 2008
    Illinois
    Re: 034 Motormounts
    So what then did they do or not do that made it vibrate more? Did they tell me they ran the car but did while everthing was tightened? I've heard both stories about these. Some have more vibrations but nothing terrible, others have nothing. WTF? Can this problem be fixed but loosening what needs to be loosened, idle the car and then tightened everything up, or is it too late for that?
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Re: 034 Motormounts
    this might sound crazy, but have you tried going to a.. store?
    anyway, maybe you were sent track density mounts by mistake?
    Feb 23 2004
    Stow, OH
    Re: 034 Motormounts
    wait... are you feeling more vibrations or hearing more vibrations?
    I think you may be mistaking the sound with the new exhaust.
    You can always go back and loosen everything up, run the engine, and tighten it back up.
    USP CLUB MEMBER #34
    Feb 05 2008
    Illinois
    Re: 034 Motormounts
    No there are autopart stores nearby, but nothing special. I can do the work that's not the problem. I have been busy with work due to tax time so I've been working 14 hours days so I was tired of these lying around and just took it to the shop have installed. What tools do I need in order to get this fixed. Also, how can I tell if they are track or street density? I know I ordered street so hopefully they didn't give me track.
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    Re: 034 Motormounts
    for starters, i would just make sure your snub mount isnt touching the cup.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Feb 05 2008
    Illinois
    Re: 034 Motormounts
    I will look tonight and see if it is or not. It should just be sitting in there straight and a little portion protruding right? I know that the mounts sit higher than the oem ones or was that a misconception brought up in one of the previous threads? I just want make sure becuase if it is sitting higher, won't the snub mount be sitting in there differently?
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Re: 034 Motormounts
    1. Loosen EVERYTHING, including snub, idle engine without reving, shut off engine, then tighten everything down.
    2. Search for MIKTIP's posts on cutting down tranny mount. It appears as though some claimed the tranny mount raised the engine up, but on mine it did not.
    Mine is worry free, no more vibration than when stock except maybe a little in the shift knob, but not enough to even say it's worse. It is awesome and the slop of the stock stuff is gone.
    Finally, I'd question the install period. The tranny mount is not the simplest of installs to get lined up correctly. Even if everything is loosened and then tightened up (including snub), if the tranny mount was not aligned perfectly on the install, it won't matter.
    My 2004.5 APR Stage 3+ is SOLD
    Feb 23 2004
    Stow, OH
    Re: 034 Motormounts
    Lee has spoken!!! I trust and value his input on this. You should too.
    USP CLUB MEMBER #34
    Feb 05 2008
    Illinois
    Re: 034 Motormounts
    I do trust his input and thats why when I went in to have it done, I told them exactly what Lee mentioned in his previous posts and how I wanted them installed. Did they listen, I don't know. I'm hearing more vibrations and when i rev the car, it vibrates more and I mean any thing loose will rattle. Some of the vibrations I hear are from exhaust. I don't think I would feel any vibrations from the exhaust unless something was wrong. Hearing vibrations from the exhaust is normal but exhaust shouldn't make my car vibrate more. On a side note too, after having these installed, it seems like I can hear everything in my engine compartment. Any experience this at all? Really kinda confused. What I really want to do is put back the OEM mounts and hear and feel what the exhaust does and then put the mounts back in and see what happens.
    Feb 19 2007
    Charleston, SC
    Re: 034 Motormounts
    Its time to DIY....I seriously will NEVER take my car (and future cars) to a shop. I seriously cannot think of something I cannot do myself....beside stuff like tire mounting and balancing and alignment...I am holding off on doing an alignment....because there is always something that they will do wrong/break....
    -Sami-
    Feb 05 2008
    Illinois
    Re: 034 Motormounts
    Yea I want to take care of it myself but this would be the biggest attempt for me alone. Is there any place I can go to find audi owners in my area that could help me with this? As far as exhaust goes, I should only hear the vibrations from the exhaust if everything was done correctly. The exhaust shouldn't have an effect on feeling the vibrations, right?
    Feb 05 2008
    Illinois
    Re: 034 Motormounts
    Lastly, what are all the tools that I will need in order to get this problem taken car of. If someone can provide a list, that would be helpful so that I can go around to the stores and get whatever I don't have. I have ramps to get the car off the ground. Will that be enough clearance to work with?
    Veteran Member Four Rings palewhitemale's Avatar
    Sep 22 2004
    MT
    Re: 034 Motormounts
    good topics here guys.
    1. the 034 tranny mount, when installed properly, does NOT use the large washer from the stock mount. That washer is included, along with a dust boot in the mount portion of the 034. That was the cause of a couple vocal problems here.
    2. what kind of snub are you using? I talked to the guys at 034 and apparently their snub is 1mm smaller in radius, so at idle, when there's no torquing action, it doesn't cause vibrations. I was specifically warned by them when ordering my engine and tranny mounts to use ALL of their mounts, because they're built and tested together.
    as far as the vibrations... they increase greatly compared to stock, and when it's cold (ie, in Montana@Christmas). But I've either gotten more used to it, or things have been breaking in too.
    -bill
    2003 RS6 Avant, Goodwood Green/Black - Stock
    2018 Q7 Prestige, Glacier/Cedar - Stock
    2015 Q7 TDI Prestige, Carrera White/Espresso - Totaled @ 25k miles
    2015 Q5 TDI Prestige, Scuba Blue/Chestnut - Stock
    2001.5 S4 Avant 6sp, Stg III, Casablanca/Silver - SOLD
    2008 RS4 Avus/Black - SOLD
    2012 A3 TDI Monza/Black - SOLD
    2003 RS6 Sedan Avus/Black - SOLD
    2004.5 A4 Avant 1.8t - SOLD
    Feb 19 2007
    Charleston, SC
    Re: 034 Motormounts
    OP,
    I would start off by buying one of those 250 or 300 piece Craftsman tool sets from Sears. I THINK I bought a 244 piece set, and it was MORE than enough...BUT this is an Audi and ofcourse, there are ALOT of special tools you must buy as well.
    Torx bits, and Allen/Hex bits are a must! Also, evrything is metric on this car (and newer cars as well).
    -Sami-
    Feb 05 2008
    Illinois
    Re: 034 Motormounts
    I don't know if i've stated this or not. At idle, the car feels like stock, no vibrations, nothing. When I hit the gas, thats when everything shakes and vibrates. The lower RPM's are the worst. I thought at idle I would feel more vibrations but it feels exactly the same before the car went in. Kinda confused, any ideas? Also, I have the apr snub mount.
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    Re: 034 Motormounts
    Did you get street or track density?
    I have the motor and tranny street mounts, and no issues whatsoever. When I did have the track density mounts the car had some vibration going accelerating and then none after that.
    Also, the downpipe could be hitting the frame
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Feb 05 2008
    Illinois
    Re: 034 Motormounts
    I ordered the street density ones for sure but maybe I got the track density. IDK? I have to get under the car and look at it. Hopefully I can get it figured out because my car isn't fun to drive anymore :(
    Feb 28 2006
    Pittsburgh-Philly
    Re: 034 Motormounts
    Really sorry to hear, man. It sucks when a fellow AZ'r is having problems. I can assure you that the stuff works, though.
    Without seeing video or actually being in the car, I can't determine anything for you. Your "tons of vibration" may be normal for me, I don't know.
    Mine does not vibrate. But it is a LOT louder. It's almost like the engine noise goes through the whole frame of the car now. But I like that. Car sounds bad ass from inside.
    I really don't know what to tell you other than don't ever let a shop that doesn't do tons of B6's work on your car. They work by trial and error just as much as you would doing DIY. And they don't generally care about your car like it was their own.
    Around here, B6's just aren't modded much, and as such... no shop touches my car unless it's the rare thing I haven't got tools for. And then, it's a shop that lets me stand there and micro-manage. Because they know I know more about this car than they do.
    Feb 05 2008
    Illinois
    Re: 034 Motormounts
    The car is definitely a lot louder. I know that some of that is due to the exhaust but I didn't think I would hear everything from the engine compartment as well. It seems that after I had this done, I hear every little noise from the car. It doesn't ride as quiet as stock, that's for sure but that doesn't bother me. It's only when I accelerate or rev the engine, it torques something and that makes the car vibrate. While driving I hear the exhaust but if I go to hit the gas, everything shakes, like its straining. Maybe something is hitting the frame, or maybe it's that the mounts aren't seated properly, or maybe something totally unrelated. IDK? I will try and get a video if I can, not sure how to and maybe you guys can help diagnose my problems. I do trust the shop though. They perform a lot of stasis mods and there is a guy that deals specifically with b6's regarding upgrades. If you do a search you will see they are a credited dealership. (maplewood audi) Thanks lee and if you have any suggestion on how to get a video up, let me know.
    Veteran Member Three Rings ehfour's Avatar
    Feb 19 2005
    2002 A4 1.8T
    Vancouver
    Re: 034 Motormounts
    Did you ever get this issue resolved?
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    Re: 034 Motormounts
    I have stern snub and 034 street motor mounts and stock tranny mounts, the motor wants to jump out, lol.
    I am not sure whether I should upgrade my tranny mounts
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Feb 23 2004
    Stow, OH
    Re: 034 Motormounts
    My 034 Street motor mounts and Track transmission mount are now installed following the advise found here. No extra vibrations or sounds. No shims. Everything lined up perfectly. This has really cleaned up shifing gears. Money well spent!
    USP CLUB MEMBER #34
    Mar 21 2006
    Lakeland, FL.
    Re: 034 Motormounts
    Quote Originally Posted by Maverick View Post
    I still have the stock trans mount with the street mounts and I can feel the trans. pop up from time to time.
    I'm back bitches!
    May 03 2007
    german
    heaven/hell
    Re: 034 Motormounts
    Quote Originally Posted by dirtybrd View Post
    lol, are you going to run trans mounts then?
    i am not sure that the 1.8T use the same trans mounts as the 3.0
    Mar 21 2006
    Lakeland, FL.
    Re: 034 Motormounts
    Yes, and I don't know if they're the same either.
    I'm back bitches!
    Jan 24 2008
    Minneapolis, MN
    Re: 034 Motormounts
    I'm in Prior Lake, MN. I have 034 Street Density mounts and APR snub and I get some vibration below 40 degrees. It pretty much goes away after that. PM me and I might be able to help you out. I installed all my stuff myself.
