Results 1 to 19 of 19
Thread: Wheel Spacer...
    Established Member Two Rings kido81's Avatar
    Jan 15 2008
    Staten Island, NY
    Wheel Spacer...
    a buddy of mine was reading online somewhere that i shouldn't be runing 2 different size spaces on my car because it would F-Up my quattro system.. I just wanted to make sure if this is correct. I never heard anyone say that before and i know that lot of people are running different size.. I have like 1/8" in the front and 3/16" in the back.. Not much but i hope i'm not messing it up....
    Senior Member Two Rings thebigchu's Avatar
    Oct 24 2007
    2004 Yukon Denali, 2010 Ibis S4 Prestige 6M
    San Ramon, Ca.
    Re: Wheel Spacer...
    IMO, it should make no difference at all as long as your front left and front right are the same.
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: Wheel Spacer...
    I'm pretty sure that it makes no difference. Wheel/Tire diameter is what matters when it comes down to fubaring quattro. I ran 8 mm rear, 5mm front for 25K miles and never had a problem. Running different width spacers front to rear might make understeer worse but if you don't do road courses, I doubt that you will ever notice.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Senior Member Three Rings GyzmoS4's Avatar
    Feb 07 2006
    Bronx, NY
    Re: Wheel Spacer...
    Is 12.5mm too wide for stock wheels?
    J-Fonz tuned Stg 2+
    "Two wrongs don't make a right, but it makes us even."
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: Wheel Spacer...
    Quote Originally Posted by GyzmoS4 View Post
    Personally, yes. Your wheel bearings will suffer. If you don't mind $400 wheel bearing jobs, then no.
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    Re: Wheel Spacer...
    wheel spacers are fine...to many myths about wheel bearings going out with them...it's all B.S...if you run a wider rim and wider tire willthe wheel bearings wear out sooner? of course not!
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: Wheel Spacer...
    Quote Originally Posted by revhards4 View Post
    Prove it. I think you should revisit your high school physics class lessons if you think that increasing the distance of the wheel from the hub doesn't increase the amount of wear on your wheel bearings. Aside from that, running a wider rim is hardly equivalent to running wheel spacers.
    Feb 07 2006
    Bronx, NY
    Re: Wheel Spacer...
    So is running any size spacers going to create a problem with the wheel bearing? or is it that the 12.5 is just too wide? Maybe a smaller size would be ok? To the OP, sorry for thread jacking, just trying to get a little info b4 purchasing spacers.
    J-Fonz tuned Stg 2+
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Re: Wheel Spacer...
    I run 10mm all the way around on the stock rims for over 30k miles and have never had one issue with anything.
    --Adam
    Have questions? E-mail me.
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Wheel Spacer...
    I've run 25mm in back and 10mm upfront for at least a year now with no problems (~20k miles).
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Wheel Spacer...
    anyone have pics with stock wheels + spacers?
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Sep 14 2006
    14 GLI
    Re: Wheel Spacer...
    Mine:
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: Wheel Spacer...
    Quote Originally Posted by 1997gtx View Post
    --Adam
    And there are some people with pre 01.5's who are still running stock turbos who have been chipped for 130K miles. . .what's your point? All I'm saying is that increasing the distance from the hub mounting surface on the wheel to the hub will increase the wear on the wheel bearings. I don't make these things up, do your research. Personally, I run 8 mm spacers all the way around. I am aware of the potential consequences and am willing to make the sacrifice for appearance sake. That's all.
    Feb 14 2004
    Michigan
    Re: Wheel Spacer...
    The hub is still inside the wheel smart guy The only way it would have a drastic affect on the bearings is when the inner lip of the wheel is past the hub. Spacers do little if nothing to help speed along the process of wheel bearings wearing out. It happens on cars of all makes and models with factory wheels.
    Jan 15 2008
    Staten Island, NY
    Re: Wheel Spacer...
    Thanks everyone 4 your input I do understand that running spacers is putting more stress on da bearing then having the wheel on the hub but i think since i use studs not bolts im putting more stress on da studs then da bearing
    Feb 07 2006
    Bronx, NY
    Re: Wheel Spacer...
    Mine:
    That's pretty much the look im going for. Thanks
    J-Fonz tuned Stg 2+
    Feb 17 2008
    Ottawa Ont.
    Re: Wheel Spacer...
    ugh. im not explaining this.
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: Wheel Spacer...
    If you even had the slightest understanding of thrust angles and their effect on bearing wear/performance, we would not be having this conversation, smart guy. So, Mr. bearing expert, what type of bearings are found in the wheels of our cars?
    Feb 14 2004
    Michigan
    Re: Wheel Spacer...
    To many engineers on these forums...not enough real world experience. Everyone's got a hypothetical of something that may happen and all this fluid dynamic calculations and yada yada yada. But, not to many people here try anything for themselves and see what happens, wheather it works or not. Sure your vast experience in calculations and bearing load may look good on paper but wheel bearings go out on all types of cars, with factory wheels and tires. So, if you work as an engineer try figuring that out and fix the problem, because none of the thousand wheel bearings that I replaced in my lifetime working as a tech at a dealership did any of those cars consist of having spacers.
