Results 1 to 6 of 6
    Sep 23 2006
    Houston TX
    cheap brake fluid for temp use?
    I've been waiting to install front BBK for a B6 S4 rear kit to come in, but that rear kit has been delayed. So I don't want to wait anymore. Can I pick up some cheap Dot 3/4 fluid (local Autozone or similar) to use for a couple of months, or should I suck it up and order 2L of pentosin from ECS for $20-30? I believe it takes just about 1L for a flush, so I should probably have at least 1.5L handy, right?
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Re: cheap brake fluid for temp use?
    It won't hurt.. but why do the same job twice? If you are going with the pentosin from ecs, then you might as well do it now other than later...
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Any DOT4 fluid will be fine.
    Sep 23 2006
    Houston TX
    What about a Dot 3/4 like Valvoline?
    I'm doing the same job twice since I have a Brembo 355 sitting in my garage and don't want to wait for the B6 S4 rears. Also, I wouldn't leave the Pentosin in, I would switch to RBF 600.
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 09 2004
    east bay, CA
    Super Dot 4 is relatively cheap.
    - Benny
    Registered Member Two Rings
    Mar 14 2008
    Springtown west of Fort Worth
    cheap is relative to the cost of the repair going cheap in the first place creates :)
    1999 Audi A6 Quattro Avant, 2005 Audi A4 1.8T Quattro, "the guzzler"
    <!--Will be missed -->
    2004 R32 T.Red traded it in since the road i live on now is to crappy :(
    2004 Phaeton W12 Black, 2003 911 Cab. MidNight Blue
    1999 Z3 Coupe 2.8, wow what style
