    Active Member One Ring dts0099's Avatar
    Oct 12 2007
    2005 A4 1.8 T Q M
    Chicago - St Paul
    FM/AM Reception Problems With II+ Upgrade
    So I upgraded to the II+, using a custom harness by TeddybGame and an antenna adapter. Everything works great except for reception on AM and FM, which is terrible....it sounds like I am listening to an alarm clock radio from 1992 at the Super 8 Motel.
    Anyone else have this problem? I have tried adjusting the antenna.
    Slowly But Surely...20%, II+, 2 way Remote Start, CC
    Jun 08 2007
    Orlando, Fl
    Re: FM/AM Reception Problems With II+ Upgrade
    What'd the adapter run you? I need one for my II+.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Dec 25 2004
    Earth
    Which antenna you running? Front or back?
    You should probably get in contact with TeddyB, as his harness's are usually without problems....
    Oct 12 2007
    2005 A4 1.8 T Q M
    Chicago - St Paul
    Got the antenna adapter here
    https://www.euro-parts.us/product.ph...cat=280&page=1
    and MikTip not sure if I totally understand your question.
    Registered Member Two Rings Avus Bub's Avatar
    Feb 10 2007
    London UK
    I had a II+ fitted last week and have lost AM. I was told this would be the case. It's to do with the old diversity aerial not being compatible with the +.
    When my man fitted it he had made a little loom for the aerial. He swapped the plugs over in it to get the best reception but did say I will lose AM. It's a shame because in the UK most of the sports stations are on AM and I would listen to live commentary.
    My FM is fine but I think it's still not as good as before. The MP3 makes up for that though!
    If any of you guys have an answer for better reception please chime in!!
    BUB
    -=UK 2004.5 A4 S-Line Quattro Avant 190ps=- Avus Silver/Silver Half Leather-Brushed Alloy Trim-GmbH Body Kit-18" Five Arms-Xenons-Bose-SymII+ -R Sensors etc etc.......
    Std DSMIC.Oettinger Alloy Intake.HyperBoostHX.K&N Panel.Milltek Cat' Back,100mm Tips.Neuspeed Snub.Strat' Shortshifter.KW V1 Coilovers.B7 RS4 22mm R Sway Bar.B6 S4 Front Brakes & Goodridge SS hoses DOT 5.1. OE S4 Mirrors.B7 RS4 Pedals & Handbrake Grip.Re-Mapped to 240ps & 345nm
