Results 1 to 16 of 16
    Senior Member Two Rings Monster Stealth's Avatar
    Feb 27 2008
    99 A4 1.8TQM, 93 3000GT VR4
    Fort Wayne, IN
    Vaccum Line Reduction
    Has anyone ever performed a vacuum line reduction on the 1.8T engines? Seeing as I have read about so many leaks from certain hoses in the system, I can only see good things come from the simplification. I come from the 3000GT/Stealth platform and am in the process of installing a catch can and krank vents on my 3000GT and decided it would be a good idea to do it to the A4 as well, since they are both turbo charged. First why in gods name are there so many check valves in this system? Is the pancake valve the actual pcv valve or does that just act as a restrictor between the TIP and the crankcase? I really would like to simplify out vacuum line system, but am really confused with the pcv system and vacuum diagrams. Maybe it will be easier once I tear into it? Any help is appreciated guys.
    1999 Audi A4 1.8TQM - Daily Driver
    1993 Mitsubishi 3000GT VR-4 - Fully built top and bottom end, currently breaking in.
    Feb 27 2008
    Fort Wayne, IN
    Re: Vaccum Line Reduction
    Does anyone have a key to this vac diagram? Is #16 the PCV, or is the pancake valve actually the PCV?
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Isn't that for an AWM?
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Senior Member Two Rings Durkin's Avatar
    Feb 17 2007
    '88 Nissan 300zx Shiro #341
    South Carolina
    if you have a 99, you have an AEB. that is for an ATW (2000)
    Charge air regulation, overview for engine code AEB
    Vehicles with manual transmission
    1 - Pressure regulator valve
    For crankcase ventilation
    2 - Evaporative Emission (EVAP) canister purge regulator valve -N80-
    3 - To Evaporative Emission (EVAP) canister
    4 - Check valve for Evaporative Emission (EVAP) canister
    Installed position (light/dark): as shown in illustration
    5 - Turbocharger
    6 - Fuel pressure regulator
    7 - Intake manifold
    8 - To Leak Detection Pump (LDP) -V144-
    9 - Crankcase ventilation
    10 - Check valve for Evaporative Emission (EVAP) canister
    11 - Charge air cooler
    12 - Pressure unit
    For wastegate
    13 - Charge pressure bypass valve
    Checking Page 21-11
    14 - Wastegate bypass regulator valve -N75-
    Feb 17 2007
    South Carolina
    Quote Originally Posted by Monster Stealth View Post
    That was for an ATW
    Charge air regulation / secondary air vacuum control, overview for engine code ATW
    1 - EVAP canister
    2 - From fuel tank
    3 - Evaporative Emission (EVAP) canister purge regulator valve -N80-
    4 - Check-valve for EVAP canister
    Between EVAP canister and intake manifold before turbocharger
    Installation position (light/dark side): Arrow points in direction of flow, as shown
    5 - Air cleaner
    6 - Turbocharger
    Check charge air pressure Page 21-51
    7 - Combination valve for secondary air injection
    8 - Fuel pressure regulator
    9 - To power brake booster
    10 - Check valve
    11 - Vacuum booster
    12 - To Leak Detection Pump (LDP)
    13 - Vacuum reservoir
    14 - Distributor piece
    15 - Check valve
    16 - Secondary Air Injection (AIR) solenoid valve -N112-
    17 - Crankcase vent
    18 - Check valve
    19 - To tank Leak Detection Pump (LDP) -V144-
    20 - Check valve
    21 - Charge air cooler
    With charge air pressure sensor -G31-
    Checking -G31- Page 21-63
    22 - Throttle valve control module -J338-
    23 - Recirculating valve for turbocharger -N249-
    Checking Page 21-45
    24 - Intake manifold
    With Intake Air Temperature (IAT) sensor -G42-
    25 - Pressure unit
    For wastegate
    26 - Wastegate bypass regulator valve -N75-
    Checking Page 21-57
    27 - Mechanical recirculation valve
    Checking Page 21-43
    28 - Pressure control valve for crankcase ventilation
    29 - Secondary Air Injection (AIR) pump motor -V101-
    Feb 27 2008
    Fort Wayne, IN
    Thanks that help a ton, hopefully when this is all said and done I can have a writeup and give a small review on the effects of krank vents on our engines
    Feb 27 2008
    Fort Wayne, IN
    Ok, what is the difference between #1 and #9 on the AEB diagram? If I understand it correct #9 is the actual PCV valve, and #1 acts as a restrictor to minimize oil and sludge from entering the TIP? If I am correct, I plan on running a catch can directly off the exit of #1 from TIP and eliminating it completely. Off the catch can I would run one krank vent to the valve cover. Icould eliminate the hard line going back around the engine that tees in with #9. Then I could run a krank vent from #9 to the intake manifold. What do you guys think?
    Like this
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    i guess i will post this question on here since it is relevent, but your those of your who removed your combi valve from the back of the head, What did you do with the vac link on their? It runs to under the intake mani.
    ::2002 S6
    Feb 27 2008
    Fort Wayne, IN
    Does the AEB valve cover have a breather port? I dont see one on any pics I am seeing
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    the AEB doesn't have a breather port on the valve cover. In the photo fo the vacuum diagram the actual PCV valve is just above the #9. It is the "T" at the intersection of the 3 lines there. The one is manifold vacuum, another is the crankcase pickup and the third goes to the pancake valve. The pancake valve is a metering device that only allows a certain amount of PCV gases to be recirculated. The PCV is boost referenced b/c they obviously don't want straight boost going into the crankcase. So there's a check valve there too, in the PCV.
    Feb 27 2008
    Fort Wayne, IN
    Quote Originally Posted by djwimbo View Post
    So where exactly does the excess crankcase pressure come from, what port exactly. The only things I see connected to that line is the vacuum from the manifold to the TIP. I was under the impression PCV valves vented preassure from the crankcase, but I am not seeing it here. Sorry if I am making this too difficult
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    #9 on the AEB chart is the crankcase port, it bolts to the block
    Feb 27 2008
    Fort Wayne, IN
    Sweet, thanks for the quick reply, I shouldn't have any problems hooking up my krank vents then, but I will have to tee off that #9 port like it is from the factory
    Oct 27 2007
    In the lab
    whats a krank lol?
    check out the 034 breather port adaptor, i run it on my audi and it greatly reduces the work needed to redo the pcv system
    Dec 17 2007
    MI
    Does the ATW have a PCV valve? I was sold one.....
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by timjadams View Post
    All cars from IIRC '67 and up have a PCV system.
    So, Yes, it does.
