For Cam's, Cat 3658's or 3652's, Im most like going with 3658's, I believe thats what Chris (DirtyBrd) just got as well. 3652's are known to have great upper end but lack a bit in the 4-5k range
There is NOT a REVO 30R file yet, so Im not sure how that could be my downfall
Unitronic can do whatever you would like for a file, plan on spending $899 for the software alone
Get the .82 A/R, the spool is difference between it and the .63 is less than 100rpm yet the upper end is WAY better when reving past 7k. That is unless of course you want to go with one of Mike's new TS setup's he is working on, in that case it would be .78 A/R IIRC and earlier spool than even the smallest A/R
Replace the motor hardware with OEM, no reason to waste money on ARP head bolts or any of that. The OEM bolts are perfect for the amount of power we are looking to make. The IE rods come with ARP bolts, thats the only place they are needed.
If your getting an AEB head, definitely consider a large port intake manifold with a larger TB (VR6 - 3" or R32 - 3.25").
While everyone gave me shit for it, I highly recommend and piping size change on the IC, 2.5" on the charge side and 3" on the TB side gave me a drastic increase in torque and gave a few hundred RPM earlier spool
For injectors, 550's are going to max out around 425awhp with meth, a bit less without. 660's should get you in the upper 400's, close to 500 with meth
Hope that helps
