Results 1 to 7 of 7
    Mar 31 2008
    trabuco canyon
    Down Pipes Or Any Aftermarket
    Who Knows Anything Good To Put On My 2008 A3
    I Got Blow Off Vaulve, Spacers, And Exaust
    I Want A Good Down Pipe Or Exaust
    FORGE 2.O BLOW OFF,FLOW-MASTER EXAUST, DROP IN AIR FILTER, BLACK OUT GRILL, ALL LIGHTS BLUE LED, BLUE HEADLIGHT BLINKERS, 2 MTX JACKHAMMERS, 5% TINT, 20 MM REAR TIRE SPACERS, S-LINE FRONT BUMPER
    Registered Member One Ring Audiaddict1's Avatar
    Dec 08 2007
    phoenix
    Re: Down Pipes Or Any Aftermarket
    is your exhaust 3 inch?
    Dec 08 2007
    phoenix
    techtonics tuning, milltech, eurosport,eurojet,atp,....the list can go on. It depends on the size of you exhaust like i asked be4.
    Deactivated Three Rings
    Jun 15 2007
    2007 GTI 2.0T
    Charlotte, NC
    Quote Originally Posted by a3 tuner View Post
    if your cat back bolts up to your factory exhaust without any modification you most likely have a 2.5 cat back, you will then need a downpipe thats either 2.5 to directly fit or get a 3.0 that bottles down to a 2.5 or there are reducers that you can use. 2.5 or 2.75 are better for more all around power using the stock turbo in my opinion but if big turbo is in the future you want to run a 3.0 down pipe.
    Established Member Two Rings TheMadDutchman's Avatar
    Jun 26 2007
    2007 Audi A3 2.0TSFI DSG SLINE
    Borla should be releasing a 3" downpipe very soon. Sounds like you need GIAC software. More bang for the buck than a downpipe.
    Veteran Member Three Rings BSig A4's Avatar
    Dec 26 2007
    Orange County
    ^^^^ hes got the stock with the mufflers and no res.
    dennis you should just got a full exhaust system and get dp or a tp
    Registered Member Two Rings Phil@BSH's Avatar
    Feb 21 2008
    97 A4 1.8TQM 06 GTi 07 Rabbit
    Scottsdale, Arizona
    We have the Euro Sport downpipe in stock for $459 shipped. It has a hi flow cat and mates up to the factory exhaust with no modifications required. We also have the full turboback for $829.99
    Downpipe link http://www.bshspeedshop.com/store/pr...cat=684&page=1
    Turboback link http://www.bshspeedshop.com/store/pr...cat=683&page=1
    Bulletproof Speed Hardware
