Results 1 to 14 of 14
Thread: Lug bolts
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Lug bolts
    I just put on my Champion Rf62 wheels on my 06 s4 and it seem as though the bolts are not long enough. I think im in need of a few more mm's.
    I know stock is 14x1.5-27mm ball seating.
    Any suggestions?
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    Re: Lug bolts
    no too sure that this will help, but just a FYI, I just received my Neuspeed RS10's and they sent me all new lugbolts. I measured them and they are 30mm of thread. Reason I am aware of this is because I am going to run small spacers and need to order new ones. Since this is the case, I was naturally searching for a "better" lug bolt, maybe something stronger and/or lighter. And I really did want Allen Head Lug Bolts. Well no luck and Titanium ones are like $1k +. Funny, the box of lugs seemed almost as heavy as one of the rims.
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Re: Lug bolts
    I did a search and found that RAD bolts are recommended.
    Im thinking I should go with a 14x1.5 32mm bolt.
    Does anyone know if the RAD lock bolt is compatible with the OEM lock bolt cap?
    Maybe PureMS can chime in?
    Veteran Member Three Rings KevinS4's Avatar
    Apr 05 2004
    2022 S4, 2001 S4 Avant, 2021 RS7, 2014 GT3
    Miami, Florida
    Re: Lug bolts
    I am using Porsche lugs on my RG40's
    Current: 2022 S4
    2021 RS7, 2001 S4 Avant and 2014 GT3
    Previous: 2011 A4, 2004 S4 Avant, 2000 S4, 1981 Coupe, 2016 A7 TDI, 2014 S4, 2019 S5
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Re: Lug bolts
    Wheel bolts are specific to each brand of wheel. There's no bolt that fits every wheel. Contact the wheel manufacturer to see what they recommend.
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Lug bolts
    I agree with Mike. If you end up getting something, make sure you get at least 7 turns of engagement to be safe.
    Dec 28 2005
    NY/NJ
    Re: Lug bolts
    I just ordered my lug bolts + rad wheel locks from PureMS.. also got the chrome caps for both. Why don't you do the same? I think those would look better than the stock gray caps.
    Current: 2024 SQ7, 2021 RS5
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Re: Lug bolts
    I actually prefer the gray caps over the chrome.
    Only thing I need to know is if they will fit over the RAD locks.
    Sep 17 2007
    Re: Lug bolts
    neuspeed sent me RAD bolts with my new wheels. just need longer ones now. I also looked @ porsche bolts, pretty much the same as everything else out there. I really wanted a nice set of allen drive, but only found them in 12mm and the company was in asia.
    Feb 12 2008
    Florida
    Re: Lug bolts
    Contact Champion Motorsport-they sold me and installed their RG40s with Porsche Titanium lugbolts and locks, and they weigh 1/2 of what steel bolts weigh, and have a "floating" seat that doesn't wallow out the holes. Worth whatever they cost!!! Hats off to Jesse and the Champion Motorsport crew, especially Vic!
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Re: Lug bolts
    ^ I called CM and talked to Jesse last week and he said the OEM bolts is what they use with the RF62's.
    I was only getting 4 1/2 turns with the OEM bolts so I placed an order for some Gorilla lug bolts in a longer length. Still waiting on them to be delivered.
    Jun 14 2005
    Anaheim, CA
    Re: Lug bolts
    Quote Originally Posted by MOFSTEEL View Post
    Yea, depending on offset and hub design, each wheel can be thicker or thinner. Our wheels use oem lug bolts and go 6-8 full turns fine. Good thing you took the initiative and got longer ones to be safe.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Sep 17 2007
    Re: Lug bolts
    I ended up with RAD Wheel Bolts. I did however find that Rennworx sells a Titanium Wheel Bolt Kit for their wheels for Porsche, for a mere $700[O_O] I guess money better spent than on an intake?
    Jun 14 2005
    Anaheim, CA
    Re: Lug bolts
    Quote Originally Posted by S-Fore View Post
    Wow... thats just crazy.
    -Charles@VMRWheels
