Results 1 to 11 of 11
    Registered Member Four Rings cerfus's Avatar
    Oct 16 2007
    Germans
    Scottsdale
    Honeycomb inserts
    Does any company make those honey comb grill inserts that are found in the bumpers and grilles of the RS versions and like in the new GTi's. I've found an upper grille but It will still need to be retrofitted..the bumper inserts/lower grille I cant find though.
    car info:
    Non widebody V6 99' A6 avant.
    thanks for all the help!
    ///Mcars
    looking for a sileighty..
    E39 M5 DD full Hamann exhaust h-back/ Hamann CF splitter/ Hamann C Diffuser/K&N intakes/ecu tune more to come.
    Keep your eyes peeled DG, CRFS coming your way!
    Registered Member Three Rings m-avant's Avatar
    Aug 05 2007
    cars with wheels...
    Californication
    Re: Honeycomb inserts
    I was looking for the same thing for my GTI. I wanted open grills to increase air flow, the lower right and left grills are closed:
    I found that Kamei makes a sheet that you can cut to fit : http://tinyurl.com/2dawv7
    ./mac
    baby hauler:2003 A6
    the daily: 2007 GTI
    track rig:99 M3
    old Avant (missed dearly) :2000 A4
    Oct 16 2007
    Germans
    Scottsdale
    thanks man, but im looking for the stock look, like the grill on your gti...speaking of gti's I might be picking one up this summer, maybe a little home brew'd RGTI ?...
    ///Mcars
    Oct 16 2007
    Germans
    Scottsdale
    like dat playa. I need sheets of that or the grill inserts would be nice too! the less custom cutting I have to do the better!
    ///Mcars
    Oct 16 2007
    Germans
    Scottsdale
    http://www.customcargrills.com/products.asp?id=27
    bam found it on a subie forum. its the closest i can find at least.
    ///Mcars
    Aug 05 2007
    cars with wheels...
    Californication
    Quote Originally Posted by cerfus View Post
    nice. it's got pretty good zip to it - not as zippy as my M3, but pretty good for the price of admission. I have the DSG, it's a cool piece of technology. You'll love it.
    btw - ECS Tuning has FK Race grill/mesh :
    looks a bit more like the honeycomb pattern used in VAG cars.
    ./mac
    baby hauler:2003 A6
    the daily: 2007 GTI
    track rig:99 M3
    Senior Member Three Rings massboykie's Avatar
    Mar 14 2008
    '16 Audi S6, '16 Audi S5 Cab.
    Natick, MA
    Does any company make those honey comb grill inserts...
    Does any company make those honey comb grill...
    Not sure if you are looking at perhaps fabricating these yourself, but I've also been looking for this for a while now...
    There seems to be quite a few places that has the "flatened" expanded metal, but most of them don't price it out to "Joe Shmoe" retailer. Maybe more people are interested and we can do a group buy or something.
    These guys have some, but I never actually asked them for a quote, so I don't know what a 4'X8' sheet will cost... probably not cheap...
    http://www.exmet.com
    Cheers
    Massboykie
    2016 Audi S5 Cab. - ECS Intake, K&N DI
    2016 Audi S6 - K&N DI, 10mm VCDS drop+12mm Spacers, Disc Italia+HPS 5.0
    Not to be forgotten...
    2016 Audi A3 2.0T, 2006 Audi A4 Avant 2.0T, 2002 Audi A6 2.7T, MKIV VR6 GTI & GLI, MKIII GLX & GL Jettas
    http://www.VAGLinks.com - 2000+ VAG Links!
    http://www.PlanetVAG.com - VAG Only Search Engine!
    Mar 26 2008
    Sioux Falls
    i know i know, JCWhitney for audi parts? what the hell? but you can order the black honeycomb grill sheets cheap from them. $20.99 for a 47.25" x 7.88" sheet here
    hope this helps a little.
    Jeremy
    Oct 16 2007
    Germans
    Scottsdale
    At my local german salvage yard there are like 10 wrecked A4's and they all have honey comb grilles, so im going to go pick up 2 or 3 grills and cut em' up to fit my lower inserts on meh grill. Im sketchy about metal because it dents, plastic does not, thats why I want plastic but I can buy sheets of it because for the most part its not bent to fit the OEM curve of the original honey comb grills, all those sheets you can buy are flat..
    ///Mcars
    Veteran Member Three Rings Alpinevelo's Avatar
    Dec 28 2006
    06 VW Jetta I5 daily driver bone stock 4 now
    Fountain Hills, AZ
    Also check ECSTuning under B6 or B5 A4 body options they have what I believe you are looking for. Also I have seen some Allroads sporting them www.ecstuning.com
    Good luck!
    Alex.
    C5 A6 2.7T GIAC software Stage 1, EVOMS DV Valves, Cupra spoiler lip, RS4 OEM 18" Wheels.
    Alex
    Oct 16 2007
    Germans
    Scottsdale
    thanks ill check it out.
    edit: nope, no luck, I'm just gonna go get those busted up car's grills and cut em' to fit.
    ///Mcars
