Results 1 to 21 of 21
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Piggie Pipes or Cat Back ... performance for the dollar?
    Between the VAST piggie pipes and say a decent cat back exhaust system.. which is money better spent? on overall performance...
    also is there an audio/video clip of a stock s4(or stg 1) with just the piggie pipes? wonder how much different it sounds with just the piggies
    Senior Member Three Rings YBLEGL's Avatar
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Re: Piggie Pipes or Cat Back ... performance for the dollar?
    Well I have done both and I would rather do the Piggies then the exhaust, they are well worthe it and they are cheaper then any exhaust for the most part. They make the turbos alot louder and easier to here the whistle they also let the boost come on a little earlier. I would do both or just piggies if I didnt have the cash for both
    MAINTENCE AND STAGE 3 INSTALLS DONE, PM ME, MASS/ RI LINE AREA
    2001.5 S4 SILVER 6 SPEED BUILT BLOCK AND SINGLE TURBO KIT WITH PTE 6262.
    Veteran Member Four Rings McKennaS4's Avatar
    Sep 24 2006
    2500 dodge ram diesel
    Boston, MA
    not only do you increase flow, thus increasing power, a catback also brings to the table weight reduction, a drop dead sexy exhaust note, and some pretty tips =) i say 100% go with the catback first! piggies sound pretty close to stock on a stock exhaust and although they increase flow fcoming from the manifolds, your stock catback will decrease the flow thus netting less increase in power compared to a ne catback exhaust. gl bro!
    01 Casa sedan 6MT, sport, cold
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    i got stock exhaust and piggies, big difference and i've only got k03's. Its going to sound even better with a catback. I would say it was a mod def worth doing, plus it gives me time to think about which cat back i want.
    Food for thought.
    1. I get into boost quicker
    2. Backpressure relief
    3. A little more throaty/aggressive note
    4. Hear the turbos more (turbo spool)
    5. Not extremely loud and obnoxious
    B5 S4 AWE Stage 3 - sold
    Veteran Member Three Rings Bimmer2Audi's Avatar
    Sep 10 2007
    2001.5 Audi S4
    G.R. Michigan
    I went through the same thing, and decided to go for Catback first. Honestly if you can gut the DPs yourself, do both at the same time...
    B5 S4 6MT Stage 2+
    JFONZ GWERKS-AWE Twin 1-SSAC-JHM FMIC-H&R Springs-BBS CH's 18x8.5
    Veteran Member Four Rings flips4's Avatar
    Oct 27 2006
    01.5&06 S4,04 MCS,08RangeRover, Ducati 848, YZ250F, and lots of TOOLS!
    Ocean Springs, MS
    piggies def first
    If it aint broke... Dont fix it!
    Senior Member Two Rings nocturnals4's Avatar
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    Performance for the dollar?? Piggies are FREE!! Thats the whole point. If you have any mechanical abilities, just do the piggies yourself. Took me 3/4 of a saturday to save myself the $300+. Then you dont have a decision to make about which to buy first.
    Sep 10 2007
    2001.5 Audi S4
    G.R. Michigan
    Quote Originally Posted by nocturnals4 View Post
    Mos def. Its just turning bolts and a couple bucks for gaskets and C02 Elimintaters.
    B5 S4 6MT Stage 2+
    Jan 29 2007
    08 S4 00 S4
    MD
    Save the money for the cat-back and do piggies+ cat-back in the same day/weekend. I just picked up a true dual cat back last week to go with my piggies. It sounds a lot better and you can really hear the turbos spooling now, even over the exhaust note.
    Dec 06 2007
    Calgary, AB, Canada
    You just have to consider which will yield you more exhaust flow if you are concerned about which will give you greater power gains and extend turbo life. They are both contained within the same system, so whichever restricts exhaust flow less, will be more worth while. Having said that, I agree with the above, do the piggies in your garage in an afternoon and buy the cat back.
    Active Member Four Rings
    Dec 11 2006
    Boston
    Get downpipes and hack off the rest of the exhaust, 2 for 1
    Stage 3+ RS6's
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Am I missing something? I thought you had to weld on o2 bungs. Not everyone can weld.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Veteran Member Three Rings RuS4ty's Avatar
    Mar 13 2006
    VA / MT
    ^that is one option if you decided to relocate the O2s, but a lot of people just use eliminators.
    I did piggies first and cat-back second. I honestly didnt notice that much difference with just the piggies, besides heading the turbos better and a little quicker spool time. But after installing the cat-back the difference is increase is awesome. The weight you save too makes a big difference.
    *NEW Addition: Misano Red RS4
    01.5 S4
    For sale(pm me for details):
    FRONT AIRBAGS !CHEAP!
    Stock S4 swaybar
    "I'd have one of those... if I were the sort of person that looked at my sister and thought, mmm..." - Jeremy Clarkson about the Roush Mustang.
    Aug 10 2007
    Castle Rock, CO
    Quote Originally Posted by RuS4ty View Post
    OK. relocate o2 sensors to maintain emissions passability in states where they test at the pipe, or celiminators if they don't. Right?
    Senior Member Three Rings GyzmoS4's Avatar
    Feb 07 2006
    Bronx, NY
    I did piggies b4 chip, and i definitely felt a difference. Still don't have a cat-back yet, but i plan on getting electric cutouts first and eventually installing cat-back. Here's what it sounds like with chip and piggies: http://youtube.com/watch?v=aEJGs4-vQ_Q
    J-Fonz tuned Stg 2+
    "Two wrongs don't make a right, but it makes us even."
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    nice thanks man...
    Dec 06 2007
    Calgary, AB, Canada
    You either need to get a chip with the rear O2's coded right out of the software, no longer in existence. OR if not, you need to trick the ECU into thinking that the rear O2's are reading correctly. This is done by using CELiminators which put the O2's sensor more out of the way of the exhaust stream so they pick up less exhaust and therefore have lower readings.
    Nov 23 2007
    Columbus, OH
    you can also wire in a rectifier diode and that should do the trick, cheap and easy solution
    Veteran Member Three Rings 2kblacks4's Avatar
    Jan 04 2007
    2000 black s4 6spd
    Birmingham Al
    car only has a chip and piggies cats are still on. -sorry for the none edited version
    http://s149.photobucket.com/albums/s...iggievideo.flv
    4:11 posi track out back, 750 double pumper, edelbrock intakes, bored over 30, 11 to 1 pop up pistons, turbo jet 390 horse power, where talking some fucking muscle!!
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    I went chip, then catback although my intention was to do it in the opposite order. It felt a little bit better with the catback, but the sound benefits were DEFINITELY the highlight... But I could only take a week of that "sand-blaster" sound at WOT (on the 93 oct. program) until I had to install a catback.
    In hindsight, it would've been better performance-wise to do DP's/piggies first but I wanted to hear that exquisite exhaust note first
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Veteran Member Four Rings Aggv's Avatar
    Sep 26 2006
    Ohio
    I bought a catback first because it was on sale, but i plan on doing dp's at the same time that i install the catback
    S4
