Results 1 to 11 of 11
    Veteran Member Three Rings mwbunns4's Avatar
    Feb 20 2008
    2011 Audi S4 6MT, Audi A3 TDI
    Savannah, GA
    exhaust questions???
    I am looking at getting an exhaust for my s4 and i have been told to get a custom system made at an exhaust shop. Has anyone had one made and how much did it cost? i have a budget and if i did get the custom one made what kind of muffler should be used? any help would be greatly appreciated. thanks everyone
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Re: exhaust questions???
    Custom is cool but consider the off the shelf kits have some R&D behind them. You can have more confidence in the flow characteristics and exhaust note. I've heard that the magnaflow mufflers are good though for the custom setups.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Established Member Two Rings aurora1's Avatar
    Nov 26 2006
    2000 S4
    Hicksville NY
    What kind of budget are you working with?
    Mar 07 2008
    00 imola, sleeper subaru
    nj
    I have the magnaflow w/ a custom full 3", w/ one resonator to keep it down a bit but when its wide open still quite loud. Labor and materials looking at least 1k maybe a bit more.
    Feb 20 2008
    Savannah, GA
    well i can get a vibrant or APR setup for less than 700 or so, so if i went custom i would want to spend less than that.
    Senior Member Three Rings YBLEGL's Avatar
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    I have the Vibrant 3" stainless system was only like $575 I think really cheap but great quality and sound. If you get this exhaust you will love the sounds its perfect for these cars and a nice performance gain.
    MAINTENCE AND STAGE 3 INSTALLS DONE, PM ME, MASS/ RI LINE AREA
    2001.5 S4 SILVER 6 SPEED BUILT BLOCK AND SINGLE TURBO KIT WITH PTE 6262.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I had a custom exhaust on my WRX. I spent about $750. It worked, but really wasn't that great. They didn't do the best welds and the design wasn't the greatest. Unless you pay a shop who really knows what they are doing it's not worth it. And if you do that it will cost you just as much as buying an exhaust.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Nov 26 2006
    2000 S4
    Hicksville NY
    I would go with the Vibrant exhaust. I have it on my car and it is a quality system. Chances are you would end up spending upwards of 600 on a custom cat-back depending on the muffler you choose.
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    If you are interested in the Vibrant system let me know I can get you a better price then anyone.
    Active Member Four Rings
    Dec 11 2006
    Boston
    bah it's just bent pipe... get a shop to fab you up a 3.5" and you will be fine.
    Stage 3+ RS6's
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    i just bought an awe twin 1 cat back
    i think they sound the best next to a fast intentions custom exhaust
    unless you get a really good deal on a custom one its not worth it when you can have those great exhausts
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
