Results 1 to 4 of 4
    May 12 2007
    Axle, Clutch, what else?
    TT
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Axle, Clutch, what else?
    Quote Originally Posted by Vontropnats View Post
    My car's original problem was what I thought to be a clutch issue. However, the other day, I looked under my car, and I saw this:
    http://i78.photobucket.com/albums/j1...g?t=1207091176
    When I pull my clutch out with it in gear, I hear the clutch disc spinning. But now I've noticed that my axle is detached, so I'm thinking my differential is just hanging out there, so the car doesn't drive. Also, my speedometer has a reading when the clutch is out fully with the car in gear, the reading is higher as your progress through the gears.
    Is this just a simple axle issue? If I replace the axle will everything be cool?
    Thanks so much guys.
    Looks like the CF seperated, should just have to install a new axle.
    Where is the rest of the axle, the side mounted to the hub?
    May 12 2007
    I think that is still mounted onto the hub.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    holy shit man... how does that happen!?
