Results 1 to 15 of 15
    Veteran Member Three Rings K04B5's Avatar
    May 28 2007
    Northern Virginia
    Question test-pipe code solution on '00 A4?
    Soo.... supposedly the anti-fouler mod won't work on a ATW motor. It hasn't worked on mine. I have the 2 anti-foulers in place and the check engine light has come on and stayed on. Since this won't work, would the Oxygen Sensor Modification write-up work on my car? (http://www.audiworld.com/tech/eng53.shtml)
    Feb 27 2005
    North Wales, PA
    Re: test-pipe code solution on '00 A4?
    it worked on my friends car. try another defouler
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    any negative affects for having more/extra defoulers?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Feb 27 2005
    North Wales, PA
    no. the post cat o2s are just for monitoring.
    Jun 04 2007
    Austin/DFW, TX
    im going to pick up 2 long defoulers tomorrow
    My 5-Speed Swap DIY
    - B6 USP
    May 28 2007
    Northern Virginia
    any thoughts on the sensor mod?
    Dec 05 2007
    CA LA
    hhmmm i know an easy fix. APR chip with test pipe file LOL. if you dont wana do that just play with the non foulers. 2 14mm spacers kept the cel from coming on in my AEB for 1000 or so miles then i got the APR with the test pipe file
    Junior Member Two Rings magiccat's Avatar
    Jan 30 2007
    B5 S4 / D3 A8
    Dallas
    I've found this, but can't confirm it has worked..http://forums.audiworld.com/a4/msgs/2766643.phtml
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    the OP's write up sounds good, but what car is that for? its not a B5 1.8t, why is he talking about going after the "left and right post pre-cat O2 sensors"??
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    The only test pipe solution I know of is a high flow cat.
    Jim
    I Do Werk.
    May 28 2007
    Northern Virginia
    we'll see if that angled block works in about 2 weeks. he needs to make a new batch
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    solution #3 is to rewrite the PCM, but that's the kinda stuff I pay for, whereas anything else I do myself.
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    Quote Originally Posted by magiccat View Post
    i have it on my 1998.5 and it works. the cel went away instantly.
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    I had a 2000 ATW and had 3 defoulers on there and no mil for 5k. Then I parted the car out.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    May 28 2007
    Northern Virginia
    Quote Originally Posted by quattro16 View Post
    Soo... 3 actually worked? Like add one more onto what I have in the following picture:
