Results 1 to 6 of 6
Thread: will it rub?
    Senior Member Two Rings GordoN's Avatar
    Sep 19 2007
    2007 A4 2.0T Quattro / 2010 A6 3.0T SE
    Toronto(Vaughan/Maple)
    will it rub?
    2007 A4 non-sline QUATTRO
    19" BBS LM reps ET35
    tire size 235/35/19
    2 10mm spacers on front wheels
    H&R Sport Springs with Bilstein Sport Shocks
    will this combo give me any rubbing? if so what tire size do you recommend?
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Re: will it rub?
    It will rub, and you will like it.
    But seriously, I think you may rub in the front when you hit bumps since you're using a 10mm spacer. I'm not sure though.
    Ignorance is bliss.
    Registered Member Three Rings SGVA4's Avatar
    Mar 03 2008
    07 3.2 Quat SLine, 08 MKV SE
    626 SoCal
    Re: will it rub?
    why dont you use 3mm or 5mm spacers? it will clear the reps nicely...
    Veteran Member Three Rings A4addict's Avatar
    Jan 23 2008
    '08 Audi S-line 2.0T A4
    San Diego, CA
    Re: will it rub?
    It will rub with 10mm spacers.
    I have LM reps with 3mm spacers on the front and 5mm spacers on the back when I had my H&R sport springs, and no rubbing. (Had to unscrew the top wheel well screw in the front wheel wells because that screw was rubbing my front tires.)
    Just keep the 235/35/19 and don't use 10mm spacers.
    APR 91/93/100, Forge DV, Debadged, PIAA, Blacked out filler/grille/reflectors/fog covers,
    2.5" custom catback, Remus axleback exhaust, H&R Coilovers, Vredestein Ultrac Sessanta 235/35/19 tires, 19/8.5" BBS LM reps, RS4 centercaps, EVOM intake, 35/5% tint, Lamin-X
    | Caution: Asian driver |
    Sep 19 2007
    Re: will it rub?
    Quote Originally Posted by A4addict View Post
    so you think i can get by without any spacers with no rubbing?
    or are a 3-5mm spacer needed?
    Jan 23 2008
    San Diego, CA
    Re: will it rub?
    You need 3mm's to clear the front calipers. The rear will be a little too tucked with the H&R springs drop without spacers so I slapped on 5mm's.
    It's up to you though, right now I don't have spacers in my rear because because my rear drop was rubbing bad. With your H&R/Bilstein combo, you should be fine with 3mm/5mm set-up.
