Results 1 to 17 of 17
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    spring is here.. lots of maintenence to do!!
    ok guys, i hope you can help me out here because i have alot of work to do and i dont know where to start really. i have alot of small things that are annoying me, so thats what i want to start with first.
    1. driver door handle: inside driver side is very sloppy in the handle movement.. if i replaced the handle assembly would that fix it?
    2. passenger door handle: does not work from the inside. pulled the door panel off to try and fix it. i found nothing wrong so put it back, and magically started working again! however, it just stopped working again so something is definetly wrong. what could be a fix...
    3. Floor mats: mine are in junk condition, but i can only find rubber ones. were can i get oem carpet floormats?
    4. Belly pan: mine has been missing since i bought the car, where can i get a new one?
    5. 100,000 miles is right around the corner from me. what should i do for checkup? i went stage 3 about 8k-9k miles ago which included timing belt kit and waterpump so alot of the stuff is new.. but what else should i replace/maintain?
    6. headlight bolts: i am missing the rear headlight bolts on both lights (the hard to reach ones) where can i get these?
    7. seats: my alcantra is in rough shape. driver and passanger sides needs to be washed. what can i use to wash them? driver side seat is shedding, what can i do to remove some of the alcantra peeling off? i saw a thread about shaving the seats? can i do that?
    thanks in advance everyone!
    ThorTechnik.com
    Veteran Member Four Rings Aggv's Avatar
    Sep 26 2006
    Ohio
    Re: spring is here.. lots of maintenence to do!!
    You can find the first four things at ECStuning.com.
    The rest of your questions i cant help with much
    S4
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    i'll tackle some easy ones:
    2. look again :-) it's all mechanical, so shouldn't be too hard to figure out.
    4. get a passat w8 belly pan from a dealer (or anywhere else) should be ~$50 and is perfect fit. don't forget to get the retaining 'screws' for it also.
    7. water with a little bit of soap is all you need. you can also do Mr. Clean's magic eraser (I've only used on silver alcantara, no idea what it does to other colors). Use a sweater 'defuzzer'...pick up at any walgreens or similar place. all of these have worked very well for me for the last 6 years.
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    i have stock floormats lying around my house from my 2000 that i don't use anymore. PM me if you want them, they are in really good shape.
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    i always see this about the w8 oil pan...any special reason for it, or is it just that much cheaper?
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Mar 07 2007
    Belmont, MA
    Quote Originally Posted by S4Per View Post
    thats the thing, i did take it apart and look, everything was fine. put it back on and it worked.. then it quit. ill try it again.
    as far as replacing the driver side door handle, what color do i need to get for the black/blue interior?
    ThorTechnik.com
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    Quote Originally Posted by casawhites4 View Post
    Ya I wonder this myself.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Senior Member Three Rings YBLEGL's Avatar
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    I can answer #1 becuase I had the same problem and replacing the handle housing does fix it.
    MAINTENCE AND STAGE 3 INSTALLS DONE, PM ME, MASS/ RI LINE AREA
    2001.5 S4 SILVER 6 SPEED BUILT BLOCK AND SINGLE TURBO KIT WITH PTE 6262.
    Veteran Member Four Rings ny02s4's Avatar
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    i was quoted $250 by my local Audi dealer for a replacement belly pan, lol. ECS FTW!!
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Veteran Member Four Rings Rapter's Avatar
    May 01 2004
    2009 honda CRV
    Jersey
    Quote Originally Posted by S4evr View Post
    Mine did the same and I just swapped out the spring and it now feels like the rest of them. On the inside part of the metal handle there is a split down the middle on the top portion. Make sure one of them isn't bent and causing the sloppy play. It's either going to be the spring or one of those prongs are bent and allowing play when you pull on it.
    When you take the DP off and are looking at the back of the handle. Make sure that the white cylinder thing on the cable is snapped into place. Then make sure you snap on the metal U shaped clip on over the white cylinder thing correctly
    YW
    Senior Member Three Rings wasup0818's Avatar
    Dec 07 2005
    US
    i can sell u my used decent floor mat ( OEM Carpet) PM me.
    Mar 07 2007
    Belmont, MA
    ill let you guys know about the floor mats^
    any word on the 100,000 mile service check?
    ThorTechnik.com
    Veteran Member Three Rings lsc2g's Avatar
    Jan 07 2006
    S3%2C%20Q8
    Calgary, Alberta, CANADA
    let me know if you fix the door handle.. my driver side is loose too.. i took the door apart and redid the pull cable to it and it fixed a bit but not much.. i think i need a whole new assembly .. doh
    www.eurodrivers.ca
    Calgary Canada Euro Club
    Feb 17 2004
    2013 Audi S6
    Yes, because it's that much cheaper. ECS tuning sells the W8.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Senior Member Two Rings thebigchu's Avatar
    Oct 24 2007
    2004 Yukon Denali, 2010 Ibis S4 Prestige 6M
    San Ramon, Ca.
    On the floor mats, I've always wondered about these aftermarket ones on ebay. If they're made well, they could be cool:
    http://cgi.ebay.com/ebaymotors/carpe...ayphotohosting
    Regarding the Alcantara, here's the 2 step process I did and had outstanding results.
    Use hot water with a little bit of mild dish soap and a Mr. Clean Magic Eraser. Pick up several packs because these fall apart pretty easily, but they pick up dirt like wow. Get the eraser slightly more than damp and rub in even strokes. Turn it or get a new one as it gets dirty. After you feel you got the as much dirt as you can, let the seats dry over night.
    (BTW, the other day I was putting in my JHM SSTS and I cut myself and didn't notice it and got blood on my Alcantara. The magic eraser took it out even after it had dried for 2 hours).
    The next day get a new mach 2 or similar razor and shave gently in one direction the areas where you have burrs or shedding. It should take them right up. Then vaccuum your seats and pat yourself on the back for an amazing restore job.
    Good luck!
    May 01 2004
    2009 honda CRV
    Jersey
    Quote Originally Posted by thebigchu View Post
    Good luck!
    Good god $220 shipped for floor mats??? [O_O]
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    Good luck!
    that sounds like the thing to do! never thought of using the mr. clean eraser, I'll have to try that... my drivers seat is in need of a little restoring.
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
