Oooookay, so kind of a long story but I've been trying to track down a major studder/shudder/jerking/stumble/boost leak/limp mode/car runs like shit/ problem for about 3 months now.
It developed when I was trying to get up a very snowy, slippery road and I was spinning my wheels like crazy and was in 3-4k rmps for about 30 minutes. Well after this my car started stumbling/studdering/jerk...etc...whenever I went over 8 psi or so.
When I get to about 8 psi or so it just shuts down, it makes a screech along with a sputtering gasping noise then the boost just shuts down.
I've tried EVERYTHING........
Things ruled out
N75 (swapped out with a new one)
accordion hose (new APR hose)
new spark plugs
NO boost leaks (boost tested and plugged up several small leaks)
no maf problems (unplugged it and it runs worse without it)
no cat problems (hi flow cat installed)
not a DV problem (switched out with another, no change)
Sooooooo, I decided to put in the red spring (instead of the yellow) into my Forge DV to see if there was any difference. Well I was pushing it a bit to see if there was any difference and it was acting the same as before when I hear a loud POP! I figured I just blew one of my intercooler hoses, so I limped home slowly.
Come to find out I blew apart the lower portion of my stock intercooler. What the hell? Was there a blockage here, a leak?
Here's a pic, it's where the hose connects to the intercooler from below. What could have caused this? (I know it's filthy, I keep destroying belly pans)
What is wrong with my car?
99 AEB 115k
k04 giac pc16
n75j
kenitic motorsports exhaust manifold
turbo back brullen exhaust, hi flow ghl cat, tt downpipe
lightweight crank thingy
I just replaced my intercooler and my boosting problem remains the same. Now I'm scared of boosting at all because I don't want to blow another ic apart.
Why do you think that happened in the first place? I've tried just about everything and I'm starting to worry my turbo could be bad after 30k. My wastegate has no play, the turbine spins freely with no blade damage. If I feather the throttle it will boost somewhat normal up to 20 psi.
Just to describe again what it's doing - when I punch the throttle it starts to screech around 10-14 psi, then it will jerk hard and boost just shuts down. No codes, and I don't have a laptop to log anything, that might have to be my next purchase.
So what causes a screech and jerk and also blows apart your ic?
Please help, I miss my car.
