    Active Member Two Rings actac95's Avatar
    Feb 26 2008
    '02 Ducati Monster 620
    Kansas City
    Brakes have warning sensors?
    When they get low? I took my car to a dealership (I know) for extended warranty work for an oil leak, which turned out to be the cam adjuster seals, and a transmission fluid leak. Why would they call and tell me I am in dire need of new brake pads and rotors? I didn't ask them to check that out. I am sure it is a standard practice that they look at wear items (brakes, tires) and hope the customer will think, gosh, you had better take care of it while you are at it. But I would think if I need brakes I would either get the sensor warning, or I would get the little prong screeching the disc. Any thoughts?
    Registered Member Two Rings
    Mar 14 2008
    Springtown west of Fort Worth
    Re: Brakes have warning sensors?
    i knew i needed brakes badly before my sensor ever went off, and when it did go off, i couldn't have driven more than another 500 miles
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    Quote Originally Posted by actac95 View Post
    Dealerships hate doing free work... just take a look at the caliper and see how much material is still left on the pads. When i took my CLK to replace cats under warranty, they found $5G more work that the car "needs". Funny that i had it inspected 6 months prior at the #1 customer satisfaction dealership in the US and they said the car is in great shape.
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    The front brake pad warning sensor will trip when you have about 10-15% left on your front brake pads.
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    dealer service job is to sell sell sell.
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
