Results 1 to 9 of 9
    Senior Member Two Rings joshd2012's Avatar
    Nov 20 2007
    2006 Audi A4 2.0T Quattro 6MT
    Arlington, VA
    CF Spoiler: How to Install?
    I got my Deval carbon fiber spoiler from EuroGearUSA and it is absolutely stunning. The weave is beautiful and the fit is perfect. Kudos to the guys at Deval.
    Now, the spoiler already has a ton of two-sided tape of it for installation, but I want something a bit more permanent. I don't have my own driveway, so most of the time I am running the car through a touchless car wash, only hand washing and waxing once a year. So I need the thing very secure so it doesn't fly off from the high pressure water.
    Epoxy seems to be the best solution to that, but I don't know much about the stuff. Is there a special formula that works best for this application? I went to a site with about 200 different formulas, and I have no idea where to start. Any advise would be appreciated.
    2006 Audi A4 quattro 2.0T 6MT
    Engine:
    Podi Boost Gauge / Audi Rev 'D' DV / Carbonio CAI / Blinktek Heat Shield / 034 Turbo Inlet Hose
    Exhaust: Stasis Exhaust / LaBree HFC
    Suspension: Vogtland CO / RS4 Rear Sway Bar
    Wheels: 18" Audi USP (Powdercoated Black) / H&R Spacers / Goodyear Eagle F1 A/S
    Exterior: Audi Euro Xenon Retro / Deval Rear Spoiler / Audi Filler Plate / Painted Sidemarkers
    Future: K04
    Mar 07 2008
    Ft. Lauderdale
    Re: CF Spoiler: How to Install?
    I don't have any experience with this but I would think that the 2 strips of double sided tape on the spoiler would have no problem holding it on. When you start using epoxy, you start running the risk of damaging the paint. Not to mention, installing it without getting excess epoxy on the trunk.
    I would be careful about using epoxy.
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    double tape should be enough to hold it. post it here once you install it.
    Registered Member Two Rings
    Jan 02 2008
    2007 A4 2.0t Titanium package
    Encino CALIFORNIA
    lol
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Screw the tape, put it on the right way. Go to a BMW dealer and get some Dow K1 betalink , follow the instructions on the box and have fun.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Senior Member Two Rings jayM's Avatar
    Jun 28 2007
    please do not use epoxy. Clean the bottom of the spoiler and edge of trunk with mineral spirits (takes off wax and other residue). And use double sided tape. It will hold.
    2012 Mercedes-Benz C350 4matic Sedan
    2006 Audi A4 2.0t quattro - Sold
    Vancouver, Canada
    Oct 14 2006
    MK6 Jetta
    South,FL
    Ps. Betalink holds at about 80lbs per square inch, so that thing is there for good, unless you spray it with the beta remover.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    I'd go with epoxy, seeing as I've already lost a trunk spoiler that was mounted with 2x sided-tape. My current trunk spoiler has been mounted with a silicon adhesive (black colored) and had no problems for the last 9 months.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    i heard betalink works REALLY well
