Results 1 to 10 of 10
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    s/s brake lines (firmer feel?)
    Don't really care about more stopping power, I just want a firmer feel. Is this what I should do or get pads that bite quicker?
    GO KNIGHTS!
    Feb 17 2005
    Sarasota, FL
    Re: s/s brake lines (firmer feel?)
    The pedal will be firmer as the the brakes heat up. Inital pedal feel when you first touch the brakes won't be much different but they will be more fade resistant as the fluid (and lines) start to heat up. The stock lines will "bulge" from the heat and pressure which is partially what gives you the mushy pedal. Obviously SS lines can't bulge giving you slightly better and more responsive pedal feel
    Registered Member Two Rings
    Mar 14 2008
    Springtown west of Fort Worth
    and as the car ages so do the stock rubber lines getting even softer and more likly to break, like my poor a6 i just put up on blocks yesterday, full brake line replacement and caliper rebuild :)
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    How difficult would a change of (front only) rotors, brake lines, and pads? Mine are all rusted and worn....would this also help the pedal feel and stopping power??
    barrett
    2019 SQ5 Prestige
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Quote Originally Posted by texasboy21 View Post
    barrett
    Not too difficult at all. I had some help from Clint but we did all rotors, lines and pads. The "difficult" part was retracting the rear caliper piston - which went away once we had the right tool. There are at least a couple DIYs out there and it's pretty straight forward once you see it in front of you. Use antisqueal! Bring a friend to do the pedal method for bleeding the brakes.
    I went with SS lines, Hawk HPS and plain Zimms all around. Outside of a bit of adjustment (3x) on the pad "prongs", it all worked out fine for me. My opinion is skewed since I had akebonos on the front when I got it and stock potato chips in the rear. What I will say is it was all worth it simply to see much less dust!
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Buncha motorcycles
    Memphis, TN
    SS lines and motul 5.1 fluid firmed up my pedal feel a lot
    APR Stage 2/AWE Intake
    Mar 11 2008
    B7RS4 & e46Ms
    Definitely a worthwhile investment. I've had them on my last 4 or 5 cars. Even compared to brand new rubber lines, it's a night/day difference... SS for teh win!!
    Feb 21 2008
    Orlando, FL
    I've got 65k on my car and never changed the front brake pads. I just changed my rears. That's some long life to me. I want to do the same thing to my motorcycle on the fronts, but if I do my car I'm doing it all, only $120 or so.
    GO KNIGHTS!
    Feb 21 2008
    Orlando, FL
    Quote Originally Posted by Papachristou View Post
    Isn't 5.1 silicone based?
    GO KNIGHTS!
    Buncha motorcycles
    Memphis, TN
    im not sure, but its a 2 year fluid whereas RBF is yearly.., RBF has a higher boiling point but im not tracking it so i dont want to be flushing it yearly.. 5.1 is a much better fluid than OEM and has a much higher BP than OEM as well so its a good in between of track/crappy OEM
