Results 1 to 6 of 6
    Established Member Two Rings j_sonel's Avatar
    Jan 18 2008
    '06 A6 Avant 3.2Q, '06 A4 Avant 2.0TQM
    Chapel Hill, NC
    Adapters with Spacers
    Is running spacers with adapters a bad idea? I am putting some 17" Porsche wheels on my B6 A4. 52mm offset with 25 mm adapters. If I wanted another 5-10mm to flush the wheel out with the fender, could I add spacers without issue?
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Adapters with Spacers
    I guess if the spacers and the adapters are both hub centric it may work, but that's alot of added metal between the wheel and car. I'd recommend against it.
    Senior Member Three Rings tivs31's Avatar
    Feb 07 2008
    Lemont IL
    ^ agreed
    Running adaptors + spacers leaves alot of stuff between the hub of the car and the wheel. I would personally look for a 35mm adaptor, they are out there and that way you have less moving parts in between the two surfaces
    Jun 14 2005
    Anaheim, CA
    Iv seen people at the track run spacers larger then a 25mm and havnt had a problem. I personally wouldn't do it. I don't like the feeling of knowing my wheels are spaced that far away from my hub and possibly causing damage to wheel bearings.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Jan 18 2008
    Chapel Hill, NC
    The retailer that I am getting my adapters from only has 20 and 25mm adapters.. I'll look around for some different sizes.
    Thanks for the input!
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by j_sonel View Post
    Try H&R & Rouge Engineering
    -Charles@VMRWheels
