Results 1 to 19 of 19
    Aug 25 2007
    New York
    talk to me about limp mode
    i am pretty sure that is the issue with my car. I have a revo tuned gtrs setup and i can not pull more than 5-9pounds of boost. the exhaust note is very loud and the power is non existant. I get going and floor the car and it will go nowhere and then all of a sudden when i get to 6k the power comes back. i have not had the chance to run the vag on it and will prob not be able to do till this weekend. i am also not getting any cel. thoughts? thanks1
    2004 A41.8TQM USP
    Dolphin/Black
    Titanium 18x8.5 ET35 Forgelines
    REVO//GTRS
    Veteran Member Four Rings DenverNoob's Avatar
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    Re: talk to me about limp mode
    well need to see some codes. you CAN get into limp without a CEL...although this is not dreadfully common. A boost leak would be the first cause for this...its typically small enough that the ECU only flips out momentariloly then resets as the condition deminishes...its prob a fueling problem in this case...jsut enough of a leak to cause the trims to bounce in and out of spec hence no CEL. Check for codes, then do a pressure test via the TIP and report back.
    USP CLUB MEMBER #26
    2019 SQ5 Prestige - 034 ECU Stage 1, TCU Stage 2
    - a few Golf Rs in-between -
    2004.5 QMT6 Ultrasport Loaded (retired)
    Aug 25 2007
    New York
    you think this would be cause from a faulty n75 or some issue surrounding my bpv? i know i am running way 2 stiff of a spring as when i let off the gas i get a voilent response. maybe i tore a whole in a hose near the n75. i will run the pressure test this weekend. th anks!
    2004 A41.8TQM USP
    Dolphin/Black
    REVO//GTRS
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    When i go into limp ill boost up till about 14psi then itll drop to about 5psi, hold then begin to build back up. Vag it and see if your in limp, clear the code, and see if the problem persists.
    barrett
    2019 SQ5 Prestige
    Aug 25 2007
    New York
    Quote Originally Posted by texasboy21 View Post
    barrett
    thats pretty much exactly what i am going through. i have not had the chance to run the vag on it however i do not have a cel. did you get a cel when you went through this bs?
    2004 A41.8TQM USP
    Dolphin/Black
    REVO//GTRS
    Apr 01 2007
    houston texas
    Sometimes yes sometimes no. When i wouldnt get a cel it came up as overboost something, with the cell it was upper limit exceeded from somewhere. Sorry its so vaugue but that should you enough to get the point across.
    barrett
    2019 SQ5 Prestige
    Jun 30 2007
    Raleigh, NC
    lol -- when i first saw the title of this thread all i could think was "hmm... i think fletcher (oldguy) is the only one on the forums old enough to know anything about that"
    hahahahaha
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by B6Lovin View Post
    hahahahaha
    Hey, watch it!!!!!! I still check up on you guys once and a while you know.
    (And your time will get here sooner than you think )
    Cheers
    Aug 25 2007
    New York
    update. ran some logs and found 0 codes!
    unplugged the maf and the car was running better but still had no boost. any thoughts? i hope this isnt my wastegate. could this just be a faulty n75?
    2004 A41.8TQM USP
    Dolphin/Black
    REVO//GTRS
    Registered Member Two Rings Onallquattro's Avatar
    Feb 10 2007
    97C4S, 98 Discovery, 03 A4
    Chicago
    hahahahaha
    Bwaaaaahhhhaaaaaahaaaaaaa!!!! Im 42 and Im not lookin forward to that Viagra here I come
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Limp mode usually kicks in for me somewhere around the 9th shot of whiskey...
    -Darrick
    Jun 30 2007
    Raleigh, NC
    Cheers
    i kid because i care
    im only 20... i hope my time holds off for a goooooddd while.
    so did you end up getting the benz?
    The Awesome™
    Apr 01 2007
    houston texas
    hahaha old guys and their "out dated hardware"......my grandma always told me its hell getting old, glad ive got a ways to go
    barrett
    2019 SQ5 Prestige
    Dec 28 2006
    Western Maryland
    I'm still looking. I borrowed the SLK55 for the weekend and put about 300 miles on it. The power was intoxicating. The torque started when you turned the key on and never quit! However the car was uncomfortable compared to the A4 and the gas mileage was horrendous. Granted I was beating it hard but I averaged somewhere around 11 or 12 MPG for 300 miles! Typically I am not that concerned about gas mileage, but 12 MPG at today's prices is kinda hard to ignore plus I missed shifting gears. So basically I passed on the SLK55. However we picked up a new car for the wife ('08 MB 300 sport sedan). So for now I'm driving the '03 C 230 sport and still looking. If I don't come up with something soon I think I will trade my kid for the Audi and let him drive the C 230 for a while. Long term I need to get rid of the C 230 because it now has 185K miles whereas the Audi is at 95K miles. Meanwhile work is rather hectic so I really haven't put much effort into finding a new ride. So I'll keep checking in every few days to keep up with the latest AZ news and see how you guys are doing!
    Cheers,
    Old Guy
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    i would definatly look for a boost leak, could also be a trashed diverter valve... when mine went i was loosing boost pressure like crazy until i hit higher rpm's, definatly check the DV, and look over all your turbo piping...
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Dec 28 2006
    Western Maryland
    By the way, sorry to get the thread off track. you should definitely run a boost leak check. You could also unhook and plug the hose from the N75 to the waste gate and GENTLY drive the car to see if you can get any boost. Be careful because you will be running full waste gate with no boost reduction, so be ready to back off the throttle. If it appears you are getting plenty of boost I would suspect the N75. If not the boost leak test will probably show up a problem.
    Good luck!
    Feb 06 2008
    i am almost willing to bet its a boost leak... we had a jetta come in for a tranny problem and afterwards had almost this exact problem... one of our newer guys removed/disconnected some unnecessary things and upon initial road test it had almost the same problem described here.... although i doubt you have something disconnected, i am willing to bet your diaphram has failed on your diverter valve and is now laking off boost, but when you hit high rpms, it isnt leaking the boost off fast enough to cause you as much of a problem
    snailspeed.net
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    Yeah I was about to say - i don't like to talk about it when I hit limp mode cuz i usually don't remember it
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Feb 06 2008
    rofl
    snailspeed.net
