Results 1 to 14 of 14
    Sep 29 2007
    a4. c klazz. e klazz.
    Los Angeles, jkt
    Talking fender rolling??
    guys..
    what do you guys think about fender rolling??
    how much difference will it make??
    because I am having problem with tire rub issue.
    thank you...
    Veteran Member Three Rings matttl16's Avatar
    Feb 25 2007
    2007 audi a4 and 2010 audi a3
    phoenix az
    Re: fender rolling??
    i have my front fenders rolled... the rear there is really no way to roll them
    07 b7 a4 2.0t stage 3
    Active Member Two Rings OVERLOOKEDA4's Avatar
    Feb 22 2008
    2008 Audi A4 2.0t MT6
    South Florida
    I had the same problem in the front. I removed the two screws that hold the fender liner to the fender and the front doesn't rub anymore. Jack the car up and look at the top of the arch of the wheel well and that should fix your problem. Rear I don't think there is anything you can do.
    I have 19x8's with a ET30 offset.
    Hope this helps
    Tim
    2008 AUDI A4 19x8.5 VM708 SATIN BLACK w/ KUMHO ESTA SPT 235/35-19, APR STAGE 1, & NEUSPEED SPORT SPRINGS, & 5% TINT
    Jun 14 2005
    Anaheim, CA
    depending how large the problem is... most of the time fender rolling cures a lot of rubbing issues. Post your wheel and tire specs.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Mar 19 2008
    northside SD
    a fender roll is your next best friend. dooo it!
    Registered Member Two Rings Ivory 305's Avatar
    Sep 10 2007
    08' Ibis A4 S-Line/Titanium
    Miami, Florida
    i just put H & R sport springs on and i am rubbing on my rear right tire what can i do to fix this?
    APR 93// APR Exhaust// APR testpipe//H & R Sport Springs//19'' Gunmetal VMR RS4 Rims//Kumho Ecsta SPT// Podi Electronic Stepper Boost Gauge// Smoked Tail and Headlights//Debadged//Color match reflectors
    Veteran Member Three Rings A4addict's Avatar
    Jan 23 2008
    '08 Audi S-line 2.0T A4
    San Diego, CA
    Quote Originally Posted by Ivory 305 View Post
    Cut the liner where it's rubbing.
    To the thread starter: My front fenders are rolled . Nothing like a rub-free world!
    APR 91/93/100, Forge DV, Debadged, PIAA, Blacked out filler/grille/reflectors/fog covers,
    2.5" custom catback, Remus axleback exhaust, H&R Coilovers, Vredestein Ultrac Sessanta 235/35/19 tires, 19/8.5" BBS LM reps, RS4 centercaps, EVOM intake, 35/5% tint, Lamin-X
    | Caution: Asian driver |
    Sep 10 2007
    Miami, Florida
    i went to my local shop and they came in the car with me and they said it sounded like the carpet was rubbing so im either going to trim or take it out all together i understand this will make the ride a little louder when going over bumps since the carpets are made for sound insulation anyone here have their carpet removed?
    Sep 29 2007
    Los Angeles, jkt
    Talking Re: fender rolling??
    haha.. thx guys!! I finally rolled my front fenders with displacing the little screws on top of it.
    now my fronts are rub-free.
    as for my rear, i cut 1/4 part of the outer fender liner.
    the rear left is now rub free.
    However, the rear right kinda rubs sometimes when i hit a big bump .
    Should i cut more parts of the liner on my rear right?
    what do you guys think??
    I have a 245/35/19 on a 35 offset rear wheel.
    thnx again guys!!!!
    Jan 23 2008
    San Diego, CA
    I'm running 235/35/19, 35 offset, 25" rear fender height, no rubbing.
    A little bit of negative camber helps too if you don't want to replace them with 235/35 tires.
    I would definitely change tires to 235/35 though, for realness.
    Sep 29 2007
    Los Angeles, jkt
    yeah i know i should have used 235 all around..
    as for my mistake..
    besides chamber, is there anything else i can do??
    I am now running with neuspeed race springs with 2" drop.
    but my shocks are still factory.
    I am planning on getting a bilstein shock soon..
    will changing the shocks make a difference in terms of car-bouncing ??
    maybe a stiffer shock could reduce rubbing issue??
    i'm not sure so if anyone can put in their opinions??
    if yes, maybe anyone knows a specifc brand of shock people usually use to reduce rub-issues??
    thx again!
    Jan 23 2008
    San Diego, CA
    Sport shocks could definitely stiffen the travel of your tires and could help with rubbing issues. But I honestly think that you should still change your tires to 235/35.
    At some point you are going to have to replace your stock shocks to sport shocks.
    Active Member Four Rings Kemiksiz's Avatar
    Feb 21 2006
    BMW F80 Conversion- Merc A Klasse
    Turkey
    I was rolling in the rear LIKE CRAYZ! with 255/30/19 +27 offset, I did a - 2.2 camber, so I rub if its loaded, with me only or me + Gf, it does not rub..
    Instagram: @m3_rhino
    Current
    B9 A4 Avant => RS4 Avant
    Done Projects:
    F30 => F80 Full Conv
    A3 => RS3 Full Conv
    Buick Tourer => Full OPC
    Sep 29 2007
    Los Angeles, jkt
    what shock brands do you recommend ??
