Results 1 to 18 of 18
    Sep 29 2007
    a4. c klazz. e klazz.
    Los Angeles, jkt
    Talking rub issue help please!!
    guys..
    i put 235/35/19 on front & 245/35/19 on rear.
    i have rubbing issue on both end of the car..
    i used "neuspeed race" (2.0 drop) lowering springs.
    what should i do to get my car going??
    coz now it probably won't move without rubbing especially on the front end.
    i have a couple solutions in mind... which would you guys recommend?
    skkiner tires?? (move with 225/35/19)
    trim inner fender?
    change from spring to coilovers? (least prefered because expensive)
    thank you!!!!
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Re: rub issue help please!!
    get rid of the springs and get coilovers instead.
    Veteran Member Three Rings A4addict's Avatar
    Jan 23 2008
    '08 Audi S-line 2.0T A4
    San Diego, CA
    x2
    APR 91/93/100, Forge DV, Debadged, PIAA, Blacked out filler/grille/reflectors/fog covers,
    2.5" custom catback, Remus axleback exhaust, H&R Coilovers, Vredestein Ultrac Sessanta 235/35/19 tires, 19/8.5" BBS LM reps, RS4 centercaps, EVOM intake, 35/5% tint, Lamin-X
    | Caution: Asian driver |
    Sep 29 2007
    Los Angeles, jkt
    Talking Re: rub issue help please!!
    is there any other way??
    how about fender rolling ??
    what do u you guys think?
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    I would try skinnier tires. I have seen 225/35/19 on a slammed A4 on BBS wheels no issues.
    Yet.
    If you ain't rubbing you ain't Dubbing
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Sep 29 2007
    Los Angeles, jkt
    what do you think about 215?35/19 ??
    would that be too small making it look awkward ??
    thank you.
    Oct 14 2006
    MK6 Jetta
    South,FL
    How wide are your wheels ???
    -EI AL CAI.
    -Driver Mod.
    Sep 29 2007
    Los Angeles, jkt
    front: 19 x 8.5
    offest 32
    inner barrel 6.5
    outer barrel 2.0
    rear: 19 x 9.5
    offest 35
    inner barrel 7.0
    outer barrel 2.5
    thank again!!!
    bdw.. will 215/35/19 fit nicely or make it look weird??
    Oct 14 2006
    MK6 Jetta
    South,FL
    Do 215 or 225 in the front and 235 in the back.
    A good stretch looks good not weird.
    -EI AL CAI.
    -Driver Mod.
    Sep 29 2007
    Los Angeles, jkt
    215/40/19 or 215/35/19 will fit better with my rear 235/35/19 ??
    thanks again!!
    Jul 29 2007
    b7 3.2
    Can anyone chime in with some advice for me about wheels/suspension while we're at it.
    I'm looking to get some KW Variant 2's installed and some 19" BBS CH from tirerack. The tires that tirerack suggests to go with the 19's are 245/40/19. Are those going to give me any problems as far as rubbing and what not with the drop. I'm not good with wheel/tire offset data.
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    Quote Originally Posted by typerlover View Post
    Because you are going to get coil overs, I wouldn't worry as much about rubbing because you can adjust it. The OP has springs so he's got a choice to make.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Veteran Member Three Rings greg@dubaudi's Avatar
    Feb 05 2005
    2001.5 pearl WB Avant, 2016 SQ5
    Alton Bay, NH
    Get 235/35/19s and they wont rub
    2001.5 EPL/Tial 770 Pearl WB Avant///2021 SQ7 Nimbus Grey///2021 GMC 3500 Duramax
    Feb 05 2005
    Alton Bay, NH
    Quote Originally Posted by jaysoegiarto View Post
    front: 19 x 8.5
    offest 32
    inner barrel 6.5
    outer barrel 2.0
    rear: 19 x 9.5
    offest 35
    inner barrel 7.0
    outer barrel 2.5
    thank again!!!
    First off how bad is the rubbing you should be fine with 235s all around in the front jack it up and take out the upper wheel liner screw and cut off the tab and in the rear they will rub a lil till the liner rubs out a bit. there is nothing wrong with rubbing. your offsets are almost the same as mine and I tuck tire....
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    Did you do a wheel alignment when you install the springs?
    The front shouldn't rub but your rears might with a 245/35/19 tire on a 35mm rim offset. What you can do is get a wheel alignment and tell them to play with your camber settings, that's if you really want to keep the 245 profile tires.
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Veteran Member Three Rings A4 JooN 2.0T's Avatar
    Sep 24 2007
    |07 B7 A4 2.0t Qtip|
    nyc
    should of just got sport springs and or 18" wheels...imo
    2007 B7 A4 2.0t Qtip Brilliant Black on Black -=- Revo Stg 2/SPS2 -=- Milltek Catback Labree Quads -=- Eurocode Testpipe -=- K&N Filter -=- Forge DV -=-RS4 Rear Sway -=- ECS Quick Spool Pulley -=- Neuspeed SS -=- 20% 3M Tint -=- Lamin-X Yellow Fogs -=- LED UV Blacklight Interior Lights -=-O.Z Ultraleggera Black w/ Yokohama S.Drives
    Registered Member Two Rings
    Feb 26 2008
    Quote Originally Posted by HID View Post
    x2 i think thatll look good too..
    and
    DUB.fresh
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by Woadi A4 View Post
    and
    -EI AL CAI.
    -Driver Mod.
