Results 1 to 8 of 8
Thread: FMIC piping Q's
    Senior Member Three Rings spxxx's Avatar
    Jul 31 2007
    bay area
    FMIC piping Q's
    what is the best size piping for a KO4 PC-16?
    i currently have 2.5 and im wondering if it is too large for that small of a turbo...
    Laser Red 1.8tqm GT2X pc16 --> sold
    REVO + 034 Goodies >>> B6 A4 1.8tqm
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    Re: FMIC piping Q's
    2.25 its perfect
    GIAC-X, STASIS TS,VAST,034 MS
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: FMIC piping Q's
    2" is the normal size for a K03/K04 and even a stage 3 size turbo but 2.25" wont be too large. A 2.5" isn't really needed till you get up to a BAT size turbo or using this size for the cold side for a BT setup. Basic rule of thumb is to use the same size hot side IC pipe as the outlet of the turbo and a cold side pipe the same size or 1/4" larger. Really want to use the smallest size pipe possible to keep velocity up without maxing out the flow which is mach 1 for any size pipe.
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: FMIC piping Q's
    i run 2.25'' piping no problem on my setup
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    Re: FMIC piping Q's
    Quote Originally Posted by AudiRacerS4 View Post
    do you have ebay piping too? what pipe kit did you use
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    Oct 28 2006
    Re: FMIC piping Q's
    Quote Originally Posted by aaronamerica View Post
    the one that came with my intercooler
    Veteran Member Four Rings dualaudi's Avatar
    Dec 13 2004
    allroad 2.7t
    san diego
    Re: FMIC piping Q's
    so good velocity is achieved from starting small then going large?
    (sold) 1999.5tqm :: gtrs, atp 3"TP, tweaked mika t3/t4 8k, adj. fpr, forge 004, MBC, neuspeed: catback exhaust, E-bay special FMIC! 9"x28"x2.75" - SOLD
    https://www.instagram.com/dualaudi/
    Feb 17 2005
    Sarasota, FL
    Re: FMIC piping Q's
    I went against what everyone told me to try something different. Used a 2.5" charge pipe (turbo to IC) and 3" IC to TB. Quickened the spool a bit on my 3071R and gave the car a bit of a torque spike over my previous 2.25" all the way around setup!
