Results 1 to 11 of 11
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    seafoam = exhaust manifold smoke?
    never used seafoam before... i used on front vac line, smoke came out the rear about after 1oz of the stuff being sucked in. the smoke in the manifold scared me a bit. does this mean i have a cracked stock manifold? or just a leak? it got quite smokey over the turbo...
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Re: seafoam = exhaust manifold smoke?
    I personally had the smoke out of the end of the tailpipe but I never saw smoke come out of the engine bay.... sounds like some type of leak...
    Registered Member Three Rings
    Jun 21 2007
    Fort Lauderdale,FL
    Could be just a gasket.
    Dec 19 2007
    York, PA
    usually if you see smoke around the turbo, theres a leaking seal around the turbo housing...find it and gl
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    Similar experience than mine, I actually saw liquid leak between the manifold and turbo, which probably means my gasket is leaking a bit. I'd also say your gasket is leaking.
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Registered Member Two Rings quattro2003's Avatar
    Sep 29 2007
    2003 A4 1.8T Quattro
    Pittsburgh, PA
    yeah you have a leak for sure
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    If the leak was AFTER the turbo.....performance wise you are fine. But if the leak was PRE-turbo then you will suffer in the performance department!
    -Sami-
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Seafoam is notorious for eating up bad or soon to be bad gaskets. If you haven't replaced the gaskets ever then you may need to do so. On my 03 i had the OEM rubber ones and the seafoam ate straight through them. I now used polyurethane i believe.
    barrett
    2019 SQ5 Prestige
    Sep 14 2006
    Eagle Rock, LA, Ca
    i would guess its between the manifold and turbo... so yeah... i saw a little bit of liquid drip on top the turbo also..
    Quote Originally Posted by texhasboy21
    barrett
    i barely used an oz... i stopped as soon as i saw some smoke.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    The smoke from the exhaust manifold is normal, it will go away after a couple minutes. All the extra steam/fumes from the Seafoam essentially pressurizes the exhaust manifold (and the molecules are smaller than exhaust molecules) so they leak out through the gasket. It will re-seal itself once all the Seafoam burns off.
    -Darrick
    Sep 14 2006
    Eagle Rock, LA, Ca
    Quote Originally Posted by Capt. Obvious View Post
    im really more worried about the small amount of liquid dripping... but i will retest it if its infact steam, or something else. in any case, can anyone direct me to a new turbo - manifold gasket?
    thanks
    -marc
