Results 1 to 3 of 3
Thread: Camber Issues
    Veteran Member Three Rings 07audi4's Avatar
    Dec 06 2006
    2007 audi a4 2.0T quattro
    rochester, new york
    Camber Issues
    ive been lowered on neuspeed race springs for about 20,000 miles now and have gone thru 2 sets of tires. the camber is crazy. when i called neuspeed they told me that everything can be put back to the factory specs but noone seems to able to do that. is there any way to help the front tires so they dont wear so much? ive read that the camber on the back wheels can be adjusted back to normal so i have to get that done because I am starting to see some inner wear on the back tires. the last thing I noticed is that after my rear sway bar install the outside of my back right tires had worn down to the threads...any ideas?? Thanks in advance!
    chris
    2007 AWE Tuning Audi A4 2.0T Quattro
    APR Stock 91 93 Race / Evolution Motorsports Intake / AWE Tuning Front Mount Intercooler / AWE Tuning Downpipe Back Exhaust / Neuspeed Race Springs / H&R S4 Front And Rear Sway Bars / Fog Light Mod / 10% Tint With Custom Audi Emblems In Rear Windows
    Registered Member Two Rings coryliv's Avatar
    Feb 09 2006
    VA
    Re: Camber Issues
    I have minor camber issues as well. I was told I needed to buy a camber kit to allow for more adjustment. The wear on the tires has been so minor I haven't explored getting a kit.
    ________________________
    2006 A4 2.0T Quattro
    Moro blue, grey leather, 6 spd, sports suspension, GIAC, RS4 rear sway
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B9Q5
    Honolulu, HI
    Re: Camber Issues
    Get an alignment. It's the toe-in that killing your tires. Get it set to as close to zero as possible. The only camber adjustments that can be made is in the rears. The fronts need adjustable control arms.
    Current:
    2024|A5 SB PP+ S-line, 2019|Q5
    Previous:
    2017|S3, 2016|A4 2.0T Quattro, 2006|A4 Avant 2.0T Quattro S-line, 2005|A4 3.0 Quattro UltraSport
