Results 1 to 17 of 17
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Camber, Toe Settings
    Well getting my NS Sport springs installed Wendsday, then its time for an allignment. I was gonna go with -1.25* in the rear, have them get it as close to -1.5* in the front, and 0* toe all around. This is what I found after searching. Now I have a few questions...
    1. Will they be able to get the rear to that spec, and 0* toe on all 4 wheels.
    2. Is the front camber/toe adjustable at all?
    And I really dont know how our AWD system works, but what % of power goes to the front and rear wheels?
    Thanks
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Nov 04 2007
    Minnesota
    Re: Camber, Toe Settings
    Bump
    Current:
    Jun 08 2007
    GLI
    Orlando, Fl
    The camber is not adjustable in the front but it is in the rear.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Mar 27 2005
    The Cold North
    Quote Originally Posted by gotboost View Post
    You probably read this when you did all your searching but. Your front camber is dictated by ride height. Your rear camber is adjustable. Toe is adjustable at all 4 corners and a decent shop should be able to set it at '0' all the way around. I take it you have driven a car with '0' toe and understand it's higher speed handling characteristics.
    Search for Torsen AWD and they will explain the quattro system. I belive your setup is a 2:1 bias.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Quote Originally Posted by EBG 18T View Post
    please explain
    -Sami-
    Mar 27 2005
    The Cold North
    please explain
    I'll attach a link for specific info, but here are the basics. There are several books avalaible that talk about chassis dynamics and alignments.
    With the way our roads are (rutted) many places will spec 1/8"-1/16" toe in to provide stability at higher speeds and have predictable tracking. IIRC OEM spec was in the 1/8" range. Neutral ('0')to 1/32" Toe Out will provide better initial turn in, BUT it will lack some stability at higher speeds. Some people won't notice it, some will. Neutral can have an 'edgy' feeling on the highway when you change lanes. It seems like hyper lane changing.
    Use caution when playing with out of spec Toe settings. Hope this helps.
    TireRack website - alignment info.
    2020 Chevy AEV ZR2
    Nov 04 2007
    Minnesota
    Well most of my driving is done on the highway, but I also autocross a couple times in the summer, so do u recomend getting toe set to 1/32 in on all 4 corners then...
    Current:
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 10 2004
    east bay, CA
    front camber non adj from the factory, rear is.
    i would go at least 1/16" in per side up front. and you can match that in the back, OR if you feel really adventuous, and since you autox, do 0 or even 1/16" out in the rear : ) that makes for some fun : ) hahah
    - Benny
    Nov 04 2007
    Minnesota
    but is it that bad at high speed with 0 toe, never driven a car with 0 toe
    Current:
    Mar 27 2005
    The Cold North
    It isn't that bad, but it all depends what you are used too. 1/32" in is a nice compromise. I would look at doing the 1/32" Toe In front & rear. If you want better turn in for auto-x do 1/32" Toe in Front and 0 toe in the back. This will help with rotation.
    2020 Chevy AEV ZR2
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    I try to run zero toe all around. The car just has a tendency to "wander" back and forth across the lane with it set at zero. It's hardly noticable until you get up to 80 or so. It helps tire life a lot.
    -Darrick
    Nov 04 2007
    Minnesota
    Quote Originally Posted by Capt. Obvious View Post
    when u say back and forth, do u mean side to side, is it like driving in a high wind
    Current:
    Nov 14 2006
    Gig Harbor, WA
    Yeah, kinda. Ever driven on a well-worn road that has grooves worn into it right where your tires go? Know how your car wants to follow the grooves and moves back and forth? It's like that, but controllable and not really discerning or anything though.
    -Darrick
    Nov 04 2007
    Minnesota
    Ok, well I hate when that happens, so Iam probley gonna go with 1/32" in, but when auto-x and road racing will i be able to feel a big differance bettween the 2
    Current:
    Mar 10 2004
    east bay, CA
    for autox and raod racing, i would not use the same setup/alignment.
    you want to be a bit loose at autox, but i would not want that on a road course. i'd rather have a little understeer for track days.
    tow in for sure on track days.
    and how do i explain toe out... umm, when you hit an irregularity in the road, instead of the car just tracking straight, it will want to dart around a bit. i would recommend driving with both hands on the wheels, and be more alert.
    - Benny
    Nov 04 2007
    Minnesota
    so the to comprimise for both i should get it set at 1/16 in probley, right
    Current:
    Apr 07 2004
    2003 A4 1.8TQM
    Oakland
    just do 1/16" if ur so worried, with 0 toe, your rear end is happy (if u like this) thus y ur car will dart side to side on a freeway. If you run 0 toe all around stay clear of any abnormalities on the roadway as it will cause ur car to act liek a sled in high wind
