Results 1 to 8 of 8
Thread: Squeekin noise?
    Registered Member Two Rings
    Aug 13 2007
    Audi A4 99 Quattro
    Question Squeekin noise?
    My suspension,control arms, or springs are making some squeeking bed noises.. It seems to make a noise everything i turn the wheel or when I'm driving slow on little bumps or bumpy roads. What can be the problem? When I push down on the hood it makes that sound? You think my spring is busted? It still drives smooth but that sound is irratating and need to know what the deal is..
    Veteran Member Three Rings black00A4's Avatar
    Oct 19 2006
    Ontario, Canada
    Re: Squeekin noise?
    I have this same issue and I think it is the control arm joints. I am going to be changing all my control arms soon so hopefully that cures it. Post up if you find out what it is.
    2000 Audi A4 2.8L Quattro Sport - Volcano Black
    Mods: 18" A8 Rep's, Ebay SS & Strut tower bar, PureMS Snub mount, K&N, MAF de-screened, H&R sports, STERN power ring & diff mounts, Cupra Lip, DEPO ecodes, Unitronic flashed ECU, Magnaflow
    Aug 13 2007
    Audi A4 99 Quattro
    Re: Squeekin noise?
    Cool you do the same too.
    Thanks
    Aug 13 2007
    Audi A4 99 Quattro
    Re: Squeekin noise?
    Yup it is the control arms. Mainly the upper one so I am going to change my whole front suspension so I won't get that problem again.
    Veteran Member Three Rings endlesswinterco's Avatar
    Sep 18 2006
    Baltimore, MD
    Re: Squeekin noise?
    also take a look at your tie rods. mine was squeaking under low speed bumps, and low speed wheel turning. turned out to be a jacked up tie rod.
    Arsenal Gunners!!
    06 Acura TSX
    SOLD: 98.5 2.8Q Laser Red
    Senior Member Two Rings jinx's Avatar
    Nov 01 2006
    01 Audi A4 1.8tQ
    CO
    Re: Squeekin noise?
    Quote Originally Posted by endlesswinterco View Post
    Completely off topic, but do you have the full sized pic of your av?
    01 A4 1.8t Quattro
    Veteran Member Four Rings superman_006's Avatar
    Jan 14 2007
    Porsche 996 C2
    WV
    Re: Squeekin noise?
    If you touch each part and have a freind push down on the hood, It should be easy to figure out which part is squeaking.
    2015 Audi Q5 S-line 3.0T
    Feb 24 2004
    Minneapolis
    Re: Squeekin noise?
    Sounds pretty gheto, but I got a grease gun with a needle, pushed the needle into the rubber boot and filled it with grease. Haven't heard a squeek for about 30,000 miles now. This was on the two uppers.
