Results 1 to 10 of 10
    Established Member Two Rings kobefans's Avatar
    Nov 19 2006
    Vancouver
    Is the shop trying to rip me off? Help please
    So long story short, my car has a inspection notice from police, so I have a shop to inspected. He called me the next day telling me that my left front CV shaft ( spelling? ) needs to be replaced and quoted me 400+ dollars for the parts alone. Otherwise i cannot pass the inspection.
    So I called around found that some shop told me that I dont need to replace the whole cv shaft, i just need to replace the joint. And some other shaft that tell me that i can just replace a new one or a re-built one for 200 dollars or less.
    So, what should a CV shaft or CV axle cost ? and what should i really need to relace
    thanks a lot in advance for any help !
    Kobe
    97 QMT
    Bilstein sports + H&R race || Ebay Short Shifter || ASA 18 black mesh wheels || DEPO 2-piece Headlight || 6000k HID || Smoked Taillights || Carbon Fiber Hood || chipped APR 91 Program
    exhaust to be done !
    Registered Member Two Rings SilverB5A4's Avatar
    Jan 19 2007
    RIP '01 A4 1.8TQM, 96 VR6 GTI
    GA
    Re: Is the shop trying to rip me off? Help please
    Drive shafts cost i think 130 from germanautoparts.com for your car i believe. Check it out.
    GIAC chip - Koni coilovers - Purems Boxster calipers and A8 rotors - CPP Adjustable Front and Rear upper control arms - H sport sways - B7 S4 BBS CH 18" - 2.8 transmission
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    $200 for the joint is about correct plus probably 2 hours labor, should be around $350-$400 total. Just the joint kit can be bought here for $150. http://www.ecstuning.com/stage/edpd/...ory=Driveshaft
    Nov 19 2006
    Vancouver
    Quote Originally Posted by SilverB5A4 View Post
    so the joint is included in the CV shaft? which means it is actually cheaper to replace the CV shaft, which is the whole thing , than replace the joint , correct?
    97 QMT
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    200 for the joint is ridiculous. For 200 raxles.com will send you a fully remanufactured axle with two brand new CV joints. It is just as easy to swap the whole axle as it is to do a joint. The only tricky part is popping it out of the hub and even that isn't all that bad. Hell, if I can do it anyone can.
    Jim
    I Do Werk.
    Nov 19 2006
    Vancouver
    the thing is the shop won't let me pass the inspection ( they are certified inspection facility) unless i replace the whole CV shaft....
    SO which way costs less money? Replace the CV joint or the CV shaft?
    97 QMT
    Feb 27 2005
    North Wales, PA
    i would buy an axle from raxles and have them install it. I'm always skeptical on whether or not a shop replaces the axle. It would be so easy for them to just clean it and put a new boots on them to pass them off as a new one.
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    If other shops quoted you less, why not bring it to them and have them inspect it afterwards.. of if they can't inspect it, have them do the work, then bring the car back for inspection. When someone tries to rip me off, I do whatever I can to make sure they get very little or none of my money. I wouldn't even buy the part and let them do the labor. I say buy the part and have another shop do the labor or even better.. do it yourself.
    Dec 12 2006
    Charlotte,NC
    Quote Originally Posted by kobefans View Post
    Thats straight garbage... Go to another shop and change the joint and bring it to another place to inspect it.
    MK4 GTi 1.8T converted to AWD
    New 1/8th mile 7.36@102mph-27psi 93 octane, no meth
    New build times 23psi pump 11.9@126mph-96mph in the 1/8th
    04' A4 1.8t frontrak converted to quattro, was RWD for a lil now its quattro finally
    2011 JSW Tdi 6speed manual
    Oct 30 2006
    B8 A4 Avant 6spd
    I paid 65 dollars per used oem axle off ebay. Also rebuilding them is cheap, def sounds to me like they're trying to rip you off.
    -18 718 GTS
