Results 1 to 4 of 4
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Taping technique... how do you polish the area under the tape??
    Forgive the über noobish question, but I searched and can't find anything on this...
    I understand taping off the plastic, cracks, etc when using a PC or other powered tool, but how do you polish/wax the area that the PC does not reach b/c of the tape? You still need to apply wax to this area, and even by hand you can get some wax/polish into cracks and onto plastic...
    What's the technique for these areas?? Im really interested to know how you pros do it.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Three Rings Davect06607's Avatar
    Apr 07 2007
    Bridgeport, Ct
    Re: Taping technique... how do you polish the area under the tape??
    by hand, if you get some in the crack just wipe it right out.
    '05 S4 6mt- Jhm 93 tune, Jhm IM Spacers, H&R c/o's, 034 Density Motor & Trans mounts, Hotchkiss Sway Bars f&r, Apikol snub & R.Differential mounts, 034 snub bracket, Jhm LW rotors w/ Hawk HPS, K&N, Piggies, FI Catback w/ 8" resonators, S.S. brake lines, 034 Density strut mounts, 034 MAF Hose, 034 adj. endlinks, RNSE, JHM Solid ss.
    Registered User Two Rings Mike @ einszett's Avatar
    May 03 2007
    Austin, Texas
    The tape's edge should meet with the edge of the trim. If you still miss areas after removing the tape, apply a vinly/rubber protectant on the plastic and then treat the area. By treating the trim first, any wax or polish residue will come off easily.
    Apr 03 2008
    Orlando
    I block it off as best I can, then carefully apply the wax when I go near the cracks and plastic. If I DO get wax in the cracks I take the edge of a microfiber towel, and put it between the cracks and slide back and forth getting rid of the wax in there, or get a stove top blade (just a plastic scraper almost like a surf wax remover) and put it in between a towel and crease it over, and insert it. I dont start with wax near the cracks though, when the applicator pad barely has any wax on it, I go towards the area and very gently/carefully apply it
