    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    podi wont light up
    So my scratch and ding podi is installed and working great...except that i cannot get it to light up. I tried using the "no cut" wire taps for 14 - 16 gauge wire and it didnt work. I think the headlight switch wiring is too small. I had to use some primary wire to reach the headlight switch but i dont think thats where my problem lies. Is there a better way to tap into it?? How about cutting the headlight and ground wire then twist them up and tape em up??? Im really close to trying it. I wanna see thos thing at night!! Open to input.
    barrett
    2019 SQ5 Prestige
    Veteran Member Three Rings jojoampt's Avatar
    Jan 19 2008
    02' A4 Avant, 1.8T QM, 08' S-Line A3 MT
    Humboldt County
    Re: podi wont light up
    try to use the wire tap again. you have to squeeze REALLY hard. i used small vice grips on mine, and squeezed the shit out of it. worked great.
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    I thought my taps where bad too, but it ended up that one of the red bulb's wires were broken off and it was loose in the connecter as well. So I tried the white bulb, it worked just fine and seated properly. Dont know if this will help.
    Established Member Two Rings j_sonel's Avatar
    Jan 18 2008
    '06 A6 Avant 3.2Q, '06 A4 Avant 2.0TQM
    Chapel Hill, NC
    Test it by touching the gauge wires directly to the car's battery. White to positive, black to negative. If it lights up, your taps need work.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    1) Check to make sure the taps cut through the headlight wire insulation
    2) Make sure the LED is in the right way. If it doesn't light up try reinstalling the bulb the other way as it is polarized.
