I bought a used Snow Performance Stage 2 kit from 3.0 King. He had been using the bulkhead fitting to tap into the washer reservoir. Here is a picture of the bulkhead fitting.
So my plan was to install the fitting in the bottom of the reservoir then disconnect and seal off the hose going to the headlight washers. I didn't want my headlight washers sucking up valuable injection sauce plus they just spray all over the car and cause water spots. As it turned out, I tested them and they weren't working anyway.
Completely removing the reservoir from the car turned out to be a bigger pain in the ass than I expected. However I noticed the hose to the headlight washers had a quick disconnect on it. So I gave up on the bulkhead fitting and decided to kill 2 birds with one stone. I'm sure I'm not the first to this, but I figured I would take some pictures for your enjoyment.
Here is the quick disconnect fitting and the hose that Snow Performance provides. The red hose goes in the fitting but is too small and not snug at all. No problem, I was planning on sealing the bulkhead with GOOP anyway.
(Note: Be sure to have a bucket handy when you unplug this quick disconnect from the reservoir hose.)
Here they are GOOPed together.
Here is the other end of the quick disconnect on the stock reservoir hose.
Here they are connected together.
Here are some shots with everything hooked up.
