Results 1 to 4 of 4
    Veteran Member Three Rings Jurjen's Avatar
    Sep 17 2006
    B5 S4
    North Vancouver, BC
    climate control question.
    Is there a way to calibrate or adjust the climate control?
    I have to crank the temp setting way up 77F (25c) to get it to blow warm air. Also, in summer time, I have to set it to like 77F to get the a/c to quit blowing so hard.
    Is this normal perhaps?
    Any help would be appreciated!
    b5 s4
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Re: climate control question.
    does your ambient temp sensor work? (does the temp displayed in dash relate to the temp outside)
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Sep 17 2006
    B5 S4
    North Vancouver, BC
    Quote Originally Posted by Jsmooth65 View Post
    yeah it works fine.
    b5 s4
    Dec 06 2007
    Calgary, AB, Canada
    There is a separate temp sensor for the climate control. You could replace that and see if it helps.
