Results 1 to 3 of 3
    Jan 14 2008
    '08 A4, '06 Elmnt, '96 R33GTR
    B7 A4 stock amplifier question
    I wired up my 500 monoblock amp today and was looking at the wiring diagram listed here for the B7 A4 and my connector looks different from the one shown. Mine is numbered vertically where the one pictured is numbered horizontally. Anybody have the pin out for this type plug with my non-bose amplifier? I need the switched power for remote as well as either line-outputs or speaker outputs to sub so I can use a convertor to get RCA's for my amp. My amp does NOT have a line level input or high-level input.. just Rca's oly.. it's old skool Fosgate.
    tia for your help guys. Yes I did search that's how I know my amp plug doesn't match teh ones shown on here.
    Jan 14 2008
    Re: B7 A4 stock amplifier question
    nobody?...bump for some help here..
    Jan 14 2008
    so the white wire that is by itself in the middle of the conector is the remote wire and the red/grey black/grey (if I remember correctly) are the sub wires. you can confirm your wires are the same by looking up at the subwoofer connector and checking the colors of the wires going to it then find the same wires in the connector.
    Sysem works great but need to adjust my Line-level convertor as it is causing some distortion in the signal ad making the higher bass freq's sound like sheit.
