Results 1 to 9 of 9
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Tip Tranny questionn...
    Well I was watching some Trucks on Spike TV this morning, and I saw that they used some different gasket thing inside the transmission to have more flow of fluid to make it run cooler, with special new fluid that would help it. Just wondering, is there anything like this for our cars that we can do to prevent things F;ing up?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 04 2005
    14 MkVI, 11 Sienna AWD
    530, California
    Re: Tip Tranny questionn...
    Tranny coolers do the trick nicely.
    13 S4 DSG/Sport Diff/Drive Select
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    01 S4 Sedan MTM tune
    01 S4 Avant APR tune
    02 A4 3.0 Sport
    99 A6 Avant, w/3rd row
    01 A4 Celebration Edition, GIAC tune
    Jun 04 2007
    Austin/DFW, TX
    Do we have factory tranny coolers?
    Or do I have to add one on?
    If so, anybody ever do this?
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Two Rings tonelee1316's Avatar
    Oct 11 2006
    rancho cucamonga
    ^^^ its part of the radiator
    Genesis Autosport
    Evolution Racewerks
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    and what he installed was a shift kit where he drills out a hole in the restrictor plate and changes the fluid filter and gasket. Its really popular with the turbo 400's. Im unsure if they have that for the audi as i've never seen or heard of it.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Four Rings loustylez's Avatar
    Oct 03 2006
    2001 A4 2.8 QT
    kansas city
    Quote Originally Posted by tonelee1316 View Post
    would this have anything to do with my coolant being low one day (30v tip) and after topping it off the car seemed to shift much better?
    Jun 04 2007
    Austin/DFW, TX
    so I'm guessing that the tranny fluid flows around the radiator. But would an aftermarket cooler help?
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Three Rings A4Shizzle's Avatar
    Mar 19 2006
    San Jose, CA
    I don't think its really an issue for our cars, the stock cooler seems to do the job fine. You could use vag-com to check your fluid temp while your driving hard if you really want to know. The trucks that use those transmissions use are meant to tow heavy loads and have way more torque than our cars. Also, the slipping that the tranny does to make shifting smooth creates a lot more heat in those huge, heavy trucks than it does in our cars. He also installed a shift kit in that transmission, which makes firmer/sporty shifts by reducing the slip in the transmission, therefore keeping it cooler. If you wanted to do THAT to your car look up the "valve body" upgrade.
    No time to mod with so many things to fix...
    Jun 04 2007
    Austin/DFW, TX
    thanks alot for all the info guys.
    My 5-Speed Swap DIY
    - B6 USP
